Rear Bilstein 5100's upside down???
Discussion in 'Suspension' started by bwhit, Nov 27, 2008.
  1. Nov 27, 2008 at 8:58 PM
    bwhit
    bwhit [OP] Well-Known Member
    07 4x4 Double Cab
    I was checking out a website at offroad.com and found an article on the install of some 5100's. The picture shows the shaft boot on the bottom. This was apparantly on a 1st gen taco. Is there something different between 1st and second. I just put my 5100's on my 07 with no instructions included from DSMS and put them on the same direction the stock Billys came off. Am I missing something here??
    http://images.google.com/imgres?img...ages?q=tacoma+trucks&svnum=10&um=1&hl=en&sa=N
  2. Nov 27, 2008 at 9:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Your not missing anything. You installed them the right way. Looks like the guy @ off-road wasnt paying attention. Cant say I havent done the same hing. :eek:
  3. Nov 27, 2008 at 9:08 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    My boot isnt on the bottom
  4. Nov 27, 2008 at 9:30 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    It really doesn't matter, it will still do its job whether the boot is facing up or down.
  5. Nov 27, 2008 at 9:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Depending on the shock. Many times rebound is slower than the compresion dampening, so if the shock is fliped, for compresion, you now have the rebound dampening trying to control the spring. Its better to mount them propperly. Just my $0.02 :)
  6. Nov 27, 2008 at 11:25 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    My 5125's came from toytech with the eye-to-stud adapter mounted on the opposite end of the boot. I installed mine with the boot at the bottom - should i reverse this? rides great the way it is..
  7. Nov 28, 2008 at 1:28 AM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    Mine are mounted just like this ^^^ its the way they go on a first gen :D
  8. Nov 28, 2008 at 5:38 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Contact Bilstien and find out what the compression damping, and the rebound damping are on that shock. I cant find my info, but I belive the compression damping is speed sensative, and a slower damping rate (allowing fast spring movement), while the rebound is a single rate, and allows a slower spring movement. If thats the case, I would reverse them so the shock boot is "up".
