Rear bilstein help!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by MEDICMAN, Feb 26, 2012.
  1. Feb 26, 2012 at 10:48 AM
    MEDICMAN
    MEDICMAN [OP] Member
    2001 Tacoma V6 TRD Toytec lift.
    Bully bar, Unknown lift, Rhino Bedliner
    Spinning cookies in the snow and hit a curb. Popped my rear shock out. And now missing a bolt. How do I get it back in?
  2. Feb 26, 2012 at 10:57 AM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
  3. Feb 26, 2012 at 11:03 AM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    What he said ^^^ you're lucky it wasn't worse
  4. Feb 26, 2012 at 11:04 AM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    yep, its broke. You need to put a new one on.
  5. Feb 26, 2012 at 11:07 AM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB MGM
    Afe CAI (removed back to stock intake), TSB 4 leaf pack with Firestone Air Bags and Daystar cradels, 3rd OEM HU, Wranger All Terrain Adventure with Kevlar 265/75/16, Cali raised LED pods, Wheeler Off Road Front Bump Stops.
    Billy 5100's? Looks like you're also running a 3 inch leaf pack. Prolly topped out the shock and it snapped at the joint. Replace the rear pair with Billy 5125's which are of longer length than the 5100's and you don't have to worry about topping it out again.
  6. Feb 26, 2012 at 11:13 AM
    MEDICMAN
    The rear are 5150s. Ideas on replacing the one or both?
  7. Feb 26, 2012 at 11:21 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Number 1, stop doing donuts in parking lot,when you slammed into curb you probably forced your springs up & your left side of truck kept going left & your axle was stopped against curb causing it to snap
    p.s. I'd look for other damage too, you had to hit awfully hard to do that, may havre even sheared an axle pin
  8. Feb 26, 2012 at 11:45 AM
    Norton
    Norton Senior Member
    Monument, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C, OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; aFe POWER Magnum FLOW Pro DRY S Air Filter; NSB-AGM27F Battery w/Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; MetalMiller TRD Skid; jsi's Locker Anytime & ramonortiz55's Always on Power Outlet Relay Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades (RallyLights Harnesses, Osram 85/80W H4 & Flösser 90W H11 Bulbs); mattgecko's Underhood Lighting; ND4's Fog Light Anytime Mod; Interior & Reverse LEDs; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; 4Runner 4X4 & FJ Fog Light Switches; Husky Floor Liners; UltraGauge EM; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Toyota Bed Extender; Pop & Lock Power Tailgate Lock; ARE Z-Series Cap, SolarGard Tint; BlendMounted BEL Vector 995; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    This ^^.
    And this ^^.
  9. Feb 26, 2012 at 11:46 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    x2, you had to hit pretty damn hard to do that. Hopefully all you did was top out the shock and snap the shock.
  10. Feb 26, 2012 at 4:45 PM
    Enduromatic
    Enduromatic Well-Known Member
    matt
    albany oregon
    silver 2000 auto taco
    rebuilt leafs/ billy 5125 ome/ billy 5100
    Hey man if you have the 5150s they are prolly the 10' travel so most likely you compressed them to much rather than topped out. DID you modify the bump stops to accomodate those 5150??? If not than that is it and you need to remeasure and put in taller bumstops. Or it will keep happening with any big compression like a curb at speed.! If they are the the 10' 5150 they extend to 26+ so that is great but of course the compressed length is longer as well!
  11. Feb 26, 2012 at 4:54 PM
    Enduromatic
    matt
    albany oregon
    If you did put in right sized bumps then it has somethin to do with bein sideways and in donut turn and hittin curb. Like 4wd said look for other damage cause if was from a sideways slide it is very likely you broke something else as well. So if i were you i would get up under ther and check for play in everything from carrier bearing back. Play in rear wheels, driveline, joints slip yoke, loose or broke bolts, check leafs and shackle mounts all of it man. I had something similar happen once and actually broke the oil seal behind rear hub and leaked diff fluid. So just check it all out. Adn then remeasure and make sure your shocks actually fit your compressed and extended lengths! Good luck bud!
