Rear block question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rgarey18, Feb 16, 2017.
  1. Feb 16, 2017 at 7:27 AM
    Rgarey18
    Rgarey18 [OP] Member
    Richard
    2017 quicksand tacoma trd off-road 4x4
    Stock!
    Hi I'm new to the tw forums I have a 2010 crew cab taco with billy 5100 on all 4 corners 2.5 setting up front stock rear with tsb my question is would a 1in lift block specifically the one from low range off-road with the 1 degree taper be enough to put the rear back level with the front right now I'm a little nose high oh I'm running 285 70 17 nitto terra grappler g2 with 17x9 fuel hostage wheels with minimal scrubbing up front only in reverse does it scrub at hard turn
  2. Feb 16, 2017 at 9:47 AM
    Whitetrash
    Whitetrash Well-Known Member
    Jimmy
    San Diego CA and Enon OH
    2008 Prerunner Regular Cab SR5
    Wheeler's AAL, 5100s at 1.75, 265/75r16
    sounds like with a 1" block, it should level it back out....and that is about as high as i would want to go with a block. Have you looked into an Add A Leaf instead? Sometimes abbreviated "AAL", it will probably ride better than a block, not much more in price either, and very easy to install :)
    ChadsPride likes this.
  3. Feb 16, 2017 at 9:53 AM
    NewfoundlandTaco
    NewfoundlandTaco Well-Known Member
    Newfoundland, Canada
    06 TRD Offroad Indigo Ink
    Billy 5100 at 2.5", 1.5" blocks, tailgate theft mod, extra bed D-rings. General Grabber AT2's.
    I have the same setup with a 1.5" block and the rear is about 1" higher than the front.
  4. Feb 16, 2017 at 10:03 AM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    What you need to do it messure from the ground to the fender on the front and rear. If the rear is say 39" and the front is 41" then you need a 2" block
  5. Feb 17, 2017 at 4:22 AM
    NewfoundlandTaco
    You should always measure from the center of the wheel hub to the fender, helps when comparing to other peoples measurements as different size tires don't factor in then.
    Whitetrash, 757yotas and ChadsPride like this.
  6. Feb 17, 2017 at 5:42 AM
    Rgarey18
    Richard
    Stock!
    I've looked at the leafs but none of them offer any sort of taper to keep the driveline angle correct I ordered the 1in block from lro last night I'll try to post some before and after pics do you guys know what the torque specs are for the u bolts
  7. Feb 17, 2017 at 7:19 AM
    757yotas
    Virginia
    2007 TRD Sport
    90 ft lbs is what i have always used on a few different trucks. Never had an issue
  8. Feb 17, 2017 at 7:45 AM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    ^^^ This dudes correct, do 90. After i had my leaf packs changed out they were torqued around 70 ISH and i had some major vibrations at 30-40 mph. Torqued then myself and havent had a problem since.
