Rear bottoming out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xnathantaylorx, Aug 27, 2020.
  1. Aug 27, 2020 at 3:42 PM
    xnathantaylorx
    xnathantaylorx [OP] Member
    2007 Tacoma SR5 V6 Access Cab
    Hello all,
    I had a spacer kit installed on my 2007 tacoma. 3" front 2" rear. I also installed rear shocks that work for 0" - 3" lift. I still seem to bottom out on larger bumps. Anything I can add or change to allow the spacer lift but lessen the likelihood of bottoming out??
    Also,
    (The front struts and springs are new from last year and the rear relief springs are new last year because I had a recall on them)
  2. Aug 27, 2020 at 3:50 PM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    Bottoming out as in hitting the bump stops or bottoming out the shocks(not good)
    TnShooter likes this.
  3. Aug 27, 2020 at 8:50 PM
    xnathantaylorx
    The bump stops. Not the shocks.
  4. Aug 27, 2020 at 8:50 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Slow down or buy an actual suspension lift.
    2WD, TnShooter and whatstcp like this.
  5. Aug 27, 2020 at 8:57 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    slow down
  6. Aug 27, 2020 at 9:12 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    How much weight are you hauling?
    Are you saying you are bottoming out on the rear bumps?
    It took me a whole bed full of cement block to get close to the bumps.
    Can’t say I’ve ever bottomed with an empty bed.:confused:
    Alexely999 and Island Cruiser like this.
  7. Aug 27, 2020 at 9:14 PM
    the_black_tacoma
    the_black_tacoma Well-Known Member
    Griffin
    IN
    2008 Black Tacoma SR5 AC
    A couple
    sure your suspension isn't just stiff/rough? Spacer lifts don't do anything for ride quality.
  8. Aug 27, 2020 at 9:28 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Spacer kit moves the axle down relative to the leaf pack; it doesn't change the distance between the bumpstop and the frame. Replace the rear spacers with add-a-leafs to increase that distance. AAL also stiffens the leaf pack so it takes more force to bottom out on the bumpstop. You can also replace the OEM bumpstop with Wheelers Superbumps or DuroBumps so the impact is dampened when you bottom out.
    Island Cruiser likes this.
