Rear bounces off bumps Bilstein 5160's
Discussion in 'Suspension' started by AzChino520, Apr 19, 2022.
  1. Apr 19, 2022 at 11:02 AM
    AzChino520
    AzChino520 [OP] Well-Known Member
    2017 TRD Off-road Silver Sky
    6112 Bilstein’s, 5160 Bilstein’s
    So I haven't been able to find much feedback on this.
    I have 6112's and 5160's, besides the 5160's the rear is stock and if it matters I also have Wildpeak 265/75/16 E ratings running 35psi all around.
    Now the 6112's are phenomenal eating bumps like nothing but once the rear hits a bump it bounces or "bucks". I'm wondering if I could eventually fix the issue by adding an AAL, Bump stops or lowering tire pressure a little or maybe will resolves once I eventually add weight to the rear ?
    Any feedback helps!
  2. Apr 19, 2022 at 11:04 AM
    gillies66
    gillies66 Just Passing Through
    2020 DCSB OR
    If you’re talking about off-road, your tire PSI should be 18.
    AzChino520[OP] likes this.
  3. Apr 19, 2022 at 11:05 AM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    AAL would help or spring packs. Toyota stock springs aren't all that great. Your Shocks won't do anything!
    wi_taco and AzChino520[OP] like this.
  4. Apr 19, 2022 at 11:06 AM
    ilyace
    ilyace Well-Known Member
    2020 MGM TRD 4x4
    Stock leaf springs need to go
  5. Apr 19, 2022 at 11:07 AM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    An AAL would work, and no judgement if you go that route, but a new leaf pack would be preferable.
  6. Apr 19, 2022 at 11:10 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Trucks tend to do this when empty.
  7. Apr 19, 2022 at 11:13 AM
    MFTAF13
    MFTAF13 "If it ain't broke, fix it till it is"
    Bob
    NorCal
    13 MGM TRD OR
    Lift, sliders, skids & some other stuff.
    I have the same setup but replaced the rear leafs with General Springs HD leaf springs and haven't had any issues. The stock leaf springs were sacked.
  8. Apr 19, 2022 at 11:17 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Slow down when off-roading.
    airmax233 and AzChino520[OP] like this.
  9. Apr 19, 2022 at 11:20 AM
    AzChino520
    Well looks like everyone agrees with the stock leaf springs being shit and so I'll upgrade the leaf packs next! Thanks boyo's I've only had my truck a couple months and just like everyone here there's so much I wanna do to it and slowly but surely building her!
    I should've clarified but I mainly noticed the rear bouncing real bad when I hit speed bumps not when off roading lol sorry
  10. Apr 19, 2022 at 11:28 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    I don't think bump stops or AAL is going to help what you're describing when the truck is empty. Some weight will probably smooth it out.. that's easy enough to experiment with. From my understanding most of the replacement leaf packs help with loads and/or lift but not necessarily car-like handling when empty (and would be interested to hear from those that have replaced the leaf pack that aren't loaded down with armor and heavy bumpers.)
  11. Apr 19, 2022 at 11:31 AM
    toku58
    Mall Crawler!
    Make sure you don't get short AAL's. It will eventually make your rear springs into a "W". I'd recommend Icon 3 leaf AALs.
  12. Apr 19, 2022 at 11:34 AM
    AzChino520
    I've had a similar understanding with leaf packs as well that's why I didn't necessarily think they'd change ride quality too I thought the shocks would've improved the rear ride quality as much as the front coilovers have. I'm not looking for a smooth car ride quality just the rear suspension to ride as good as the front suspension
  13. Apr 19, 2022 at 11:36 AM
    AzChino520
    What are you running on your rear?
  14. Apr 19, 2022 at 11:46 AM
    bmgreene
    bmgreene Well-Known Member
    Brian
    L.A. Westside
    2010 PreRunner V6 SR5/OR
    Alcan Leaf Packs, OME884 Coils, 5100 shocks, U.S. Offroad Winch Mount w/Winch, Trail Gear Rear H/C Bumper, Prinsu Cabrack, DIY custom in-bed storage/sleeping deck, Sway bar delete, hidden "snorkel" intake mod, In-dash CB, Bestop Supertop, Undercover Swingbox, hood lifters, assorted lights and front spotting camera
    Stiffer springs (AAL or heavier packs) should reduce bottoming out but will make an under-damped suspension setup worse in that regard.
    If you're bouncing too much on the springs, adding some weight in the back could help smooth out the ride if it's bouncing on the springs when it's not bottomed out. Tools and recovery gear can be good for that, but strap them down if you're going to drive like you're running the Baja 500.
    More progressive bump stops (timbrens or air-bumps if you've got the $$$) should make bottoming smoother.
    There don't seem to be as many options for suspension tuning on trucks as there are for sports cars, but it's probably also less sensitive for off-road than trying to get the "road-feel" dialed in for track runs. If all else fails, air down and slow down, and know that "handling" can get to be a relative term when it comes to rough-terrain driving.
  15. Apr 19, 2022 at 12:15 PM
    toku58
    Mall Crawler!
    The short AAL; that's why I know it will make your rear leafs into a "W".
    I have the Icon 3 leaf pack sitting in my garage. I need to find time to swap them out. Got the Icons from 4WP for $210.
  16. Apr 20, 2022 at 10:13 AM
    Saskabush
    Saskabush Well-Known Member
    Adam
    Saskatchewan, Canada
    2013 TRD Sport
    Elka 2.5" DSC w/ Deaver Stage 1, Archive Hammer Hangers, SPC UCAs, Timbren bumps, TRD baja wheels, 265/75r16 Wildpeak AT4W, Greenlane Sliders, Warn slimline bumper, N-Fab spare tire box mount.
    I've been down this same road... A new leaf pack probably won't do much for the bouncing you are describing. I thought it would when I swapped in my medium duty Dakars, but it really only helped with rough terrain like washboard or hardpack snow/ice. Sharp fast bumps like speed bumps and cracks in the road are still a problem even with about 200lbs in the box at all time.
    The problem is the rear leaf mounts. They are flimsy and like to flex under load. They are also cantilevered off the c-channel frame instead of right under it. So when you hit fast bumps like that, the mounts flex and the frame twists and basically acts like a spring. But with no shock to dampen the bouncing. The solution is to replace the rear leaf mounts with beefier ones. Look into Archive Garage Hammer Hangers. I specifically mentioned having this same problem as you in another thread and Archive responded saying that's exactly what the hammer hangers were made for. I haven't put them on my truck yet but they are definitely next on the list. Lots of other members report that they helped with the bounciness of the rear end.
    bmgreene likes this.
  17. Apr 20, 2022 at 10:53 AM
    AzChino520
    That's crazy you were curious of the same issue. I just stalked your profile and saw the thread that informed you about the hangers lol for one way to go with those Elka's can't imagine how nice they ride but also appreciate the info I think I ran across those hangers once but didn't realize the huge impact they'd make. They're definitely pricey but are now on my long list of mods to add :spending:
  18. Apr 20, 2022 at 12:39 PM
    Saskabush
    Adam
    2013 TRD Sport
    Haha yeah, the Elka's are awesome! Just floats over everything... Except for fast sharp bumps lol, which is what started my quest to figure out why. I have dual speed compression adjustment on the shocks. Yet when I adjust the high speed compression I find it really doesn't make much difference with bumps like that (which it should), only larger hits like train tracks and drop offs it seems to make a difference for. Now I know why. The frame and leaf mounts are "handling" those bumps so they aren't even really reaching the shocks. Kinda wish I would have started with hangers now!
  19. Apr 20, 2022 at 12:50 PM
    AzChino520
    Yassssss literally I mean I know I'm only rocking Bilstein's but the 6112's react so well when I hit any type of bump on or off road and I was disappointed when I discovered the 5160's made no real difference once the back end went over. So thank you for the great info, we're definitely in the same boat and will be looking into adding the hangers in the near future. I'm glad I at least know what will fix it.
  20. Apr 21, 2022 at 7:55 AM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    The 5160s are pretty stiff on both ends. They dont let the rear end soak up, and they also dont rebound fast enough to keep the tires planted after hitting a bump, so you get the "jump" effect, especially with speedbumps.
