Rear bounces off bumps Bilstein 5160's
Discussion in 'Suspension' started by AzChino520, Apr 19, 2022.
  1. Apr 21, 2022 at 8:59 AM
    AzChino520
    AzChino520 [OP] Well-Known Member
    2017 TRD Off-road Silver Sky
    6112 Bilstein’s, 5160 Bilstein’s
    I have thought about upgrading the rears to possibly fox so that's still in question
  2. Apr 21, 2022 at 9:23 AM
    OmahTako
    OmahTako Well-Known Member
    SoCal
    Tacoma-1ea. Tundra-1ea.
    Air down
    Go slower
    Throw some weight in the back
    Get a rear spring pack
  3. Apr 21, 2022 at 9:54 AM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Yeah for example, did a 63" leaf swap on a buddies truck with 5160s. Even with just 3 leafs (very soft spring rate) the truck would buck over speedbumps, even with all the added travel of 14" 5160s. My exact rear end but with tuned shocks, will basically take almost any dip/hit without the rear tires leaving the ground since my shocks have a very soft (fast) rebound.
  4. Apr 21, 2022 at 10:58 AM
    reallifedog
    reallifedog wat.
    Jordan
    Denver
    08 Tacoma TRD OR
    5160s are too tall for stock springs especially if they've sagged at all. I was bottoming the 5160s on my sagging stock TRDOR leafs with Icon AALs. Ended up adding a 1" block to the rear until I figure out what aftermarket leaf pack I want to run.
    AzChino520[OP] likes this.
  5. Apr 21, 2022 at 11:26 AM
    AzChino520
    I've thought about that too cause theyre supposed to be fit for at least 1.5 inch lift in the rear. I think at this point imma upgrade the leaf packs then the shackles and eventually upgrade the shocks. Basically eventually upgrade the whole rear suspension :facepalm:
  6. Apr 22, 2022 at 9:06 AM
    Luke_77
    Luke_77 New Member
    I believe the true issue is the fact that in stock form the Tacoma has very little bump travel in the rear. In other words at ride hight to where the bump stop contacts the strike pad is a short linear distance. On my truck it’s about 2 inches.
    I have a 3 leaf add a leaf and bump stop extension of about 2 inches. So at ride hight I have about 2.5 inches of bump travel to bump stop contact. Mid travel conversion would make this better
