Rear Brake Drum Removal Screw Size?
Discussion in 'Technical Chat' started by Scott B., Aug 24, 2016.
  1. Aug 24, 2016 at 10:38 AM
    Scott B.
    Scott B. [OP] Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I know I've read it on here, but being lazy and looking for a quick answer, I thought I'd just ask -
    What size screw is used to press the brake drum off the axle?
    Thanks.
  2. Aug 24, 2016 at 10:48 AM
    Clearwater Bill
    Billy
    Largo Florida
    I've use that method to get a rear rotor off the hub on another marquee, and the spare hold down bolt was the proper size (handy huh?)
    But I've not had to do that for a drum removal. Ever.
    Make sure the ebrake is off and pull. If no luck, back off the adjuster and try again. Still no luck, beat it around the edges with a heavy rubber mallet.
    I don't know your specfic answer, but thought I'd toss out some other options, just in case you'd not tried them.
    HisDad likes this.
  3. Aug 24, 2016 at 11:03 AM
    Scott B.
    Scott
    Georgia
    I appreciate the suggestions, and have used them all on other vehicles.
    On this truck, I have not yet tried to pull the drums off - I am just wanting to be prepared if I need work at pulling the drums.
  4. Aug 24, 2016 at 11:04 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    I believe it is 8mm x 1.25. I did this a few weeks ago and the bolt method worked great!
  5. Aug 25, 2016 at 8:54 AM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    you can also just remove two bolts from the skid plate. They will fit.
    nickrick78, tacotruck93 and 327 like this.
  6. Sep 12, 2019 at 2:30 PM
    tacotruck93
    tacotruck93 Well-Known Member
    Zach
    Akron,Ohio
    2012 TACOMA TRD OFF ROAD
    Fucking pro ass tip haha
  7. Sep 12, 2019 at 3:31 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Just back the adjuster off first !
    Since there is only a few threads in those holes the minute you put real pressure on the threads they will just strip.
    Best of luck
  8. Oct 1, 2019 at 5:45 AM
    nickrick78
    nickrick78 Well-Known Member
    Nick
    Pittsburgh PA
    Tacoless for now
    M8x1.25
  9. Jan 29, 2021 at 3:53 PM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    DUDE you are a life saver. this was a great tip. thanks
