Rear brake drum weight is missing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoma man, Feb 4, 2010.
  1. Feb 4, 2010 at 6:11 AM
    tacoma man
    tacoma man [OP] Well-Known Member
    Rochester NY
    2018 Limited 4wd Magnetic Gray
    Rear brake drum weight is missing. Is this something to get fixed? One dealer said forget about it and another said same thing won't cover it. 20,000 miles. Any ideas? Thanks.
  2. Feb 4, 2010 at 11:56 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Are you getting any vibrations?
    If no...then I wouldn't worry about it. Just keep an eye on your brake shoes & such in case they're wearing funny or the drum gets warped.
  3. Feb 4, 2010 at 12:15 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    its a weight to balance the drum,kinda like a weight to balance the tires,probably want notice it.
  4. Feb 4, 2010 at 12:26 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    If it does give you the shakes there are some shops that will balance with the wheel on the truck... the only downside is you have to re-balance when you change/rotate/"take-off-and-put-back-on-and-forget-which-way-it-goes-on"... :)
  5. Feb 4, 2010 at 1:42 PM
    Reepur
    Reepur Well-Known Member
    Brevard, NC
    '10 RC Black 4x4 2.7L
    265/75/16 BFG KM2 's on XD Hoss's 2.5" lift/4xBillies, OME 885's, Firestone Ride-Rites Desert Specialties UCA Volant CAI Grillcraft Grill Kobalt Slim Line Box Weathertech mats and Ventvisors. DTRL mod. 4 Lo -Trac Mod. Int. Wiper Mod. rcbs204 4x4 LEDS URD Short Shifter Plate Front bumper with Smittybilt XRC8000 winch Body Armor rear bumper with swing out tire carrier. ATO Front Skid Ultragauge BHLM
    That's weird. We make drum brakes (and calipers) where I work and I have never heard of using weights on a drum. Not saying it isn't done, but we don't.
  6. Feb 4, 2010 at 1:47 PM
    HBMurphy
    Paul
    So California Coast
    None
    Same as when you grind off to balance. Also these 'attachments' are sometimes used to minimize some frequencies - I used to 'ring' discs for GM to attempt to find designs/materials that would minimize squealing in the human ear freq's.
  7. Feb 5, 2010 at 5:20 AM
    tacoma man
    Rochester NY
    Thanks everybody. The water pump just went but every tacoma I had the water pump failed early. Had painted the drums last summer. Just noticed the weight gone washing the car and with the toyota crap going got nuts. I'll just "fogetabotit" as the say in saprano land. Thanks for the help!
  8. Aug 8, 2011 at 7:28 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Thread revival. I have also lost the weights on the brake drum and have noticed the rear tires have cupped over the last 5,000 miles. I know that can be caused by the wheel being out of balance, can the drum being out of balance cause this cupping? I'm getting new tires so if it makes sense to replace the drums to avoid cupping, I'll do it.
  9. Aug 9, 2011 at 6:36 AM
    Pugga
    Massachusetts
    Bump, could a missing weight on the drum cause the wheel assembly to be enough out of balance to cause cupping on the tires?
