Rear brake drums pulsating
Discussion in '1st Gen. Tacomas (1995-2004)' started by jdleckenbyFF, Aug 18, 2021.
  1. Aug 18, 2021 at 6:05 PM
    jdleckenbyFF
    jdleckenbyFF [OP] Active Member
    JD
    2002 3.4 4x4 TRD Tacoma
    Good afternoon! I replaced my rear drums and shoes and hardware a few weeks ago on my 2002 4x4 taco. Shoes were getting thin, wasn’t having issues at the time just wanted to get them replaced. After getting all the work done I noticed a pulsating while
    Braking. I read some posts from folks on here and believed I got some warped drums .. I pulled the parking brake and still noticed the pulsating so that pointed me to the drums or shoes. I had the drums replaced by the manufacturer and threw the new ones on. Still pulsating!! So frustrating. Should I look into something else or should I try a different make of drums. I ordered the power stop coated drums and power stop shoes and hardware from rock auto. They had no issue sending me new drums of the same make. Any advice will help! Didn’t have any issues before replacing shoes and drums
  2. Aug 18, 2021 at 6:08 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Have you made sure that there's no rust or foreign material on the mating surface of the drum and hub and that they are mating together correctly?
  3. Aug 18, 2021 at 6:23 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    1st replacement ........why ‘ power stop ‘ drums/shoes ??
  4. Aug 18, 2021 at 6:26 PM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    If the rear brakes were improperly adjusted then the front disc brakes are braking too much causing excessive heat and brake disc warpage. I would want to rule out the front brakes for excessive vibration.
    wilcam47, ekul310 and Dm93 like this.
  5. Aug 18, 2021 at 9:42 PM
    jdleckenbyFF
    JD
    I’ll pull them off and check again for any issues. Front brakes are brand new as well. And it pulsates with the parking brake when I lightly apply it around 25-35 mph. I went power stop cause I haul our motorcycles and just wanted a quality product and they had good reviews.
  6. Aug 19, 2021 at 5:55 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Have the drums checked for warp by a brake shop.
    Drums can be trued by turning on a brake lathe.
    Warped NEW drums is a common occurrence.
  7. Aug 19, 2021 at 7:29 AM
    Bob12321
    Bob12321 Well-Known Member
    Robert
    Take your drums to a parts store that still turns rotors and drums they will tell you if their true or not
  8. Aug 19, 2021 at 7:58 PM
    jdleckenbyFF
    JD
    Thanks guys. Took the drums to Oriellys to turn them and the guy said “how the hell is a brand new drum this warped?” The second set I wasn’t able to take off and have them check it but I’m sure it’s the same deal. Hopefully the third time with a different make is the charm
    wilcam47 and Black DOG Lila like this.
  9. Aug 19, 2021 at 8:15 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    rotors get warped, to be more precise they get an accumulation of brake pad material, drums get “out of round”
    wilcam47 likes this.
  10. Aug 19, 2021 at 9:39 PM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    I had the same thing happen with aftermarket rotors from the same place. It was ferocious. Vibration was so bad. I took them back and made the decision from then on it was Toyota parts all the time. First set of OEM was silky smooth.
  11. Aug 29, 2021 at 5:37 PM
    jdleckenbyFF
    JD
    Yep I learned the hard way. After 2 sets from rock auto I went and got some Toyota drums and they are nice and smooth. Very frustrating experience.
    Black DOG Lila likes this.
  12. Aug 29, 2021 at 6:23 PM
    Bob12321
    Robert
    How much were they through Toyota?
