Rear brake help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Adrian, Apr 13, 2011.
  1. Apr 13, 2011 at 6:11 PM
    Adrian
    Adrian [OP] New Member
    Adrian
    Chesapeake, VA
    98 Tacoma SR5 4X4
    I have a 98 Tacoma and would like to convert the rear drum breaks to disk breakes. Is it possible?
  2. Apr 13, 2011 at 6:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Its possible, but you loose brake performance.
  3. Apr 13, 2011 at 6:20 PM
    Adrian
    Adrian
    Chesapeake, VA
    98 Tacoma SR5 4X4
    I thought disk breaks are way better than drums?
  4. Apr 13, 2011 at 6:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Depending on application, and weather or not the booster supports the extra fluid for disks.
  5. Apr 13, 2011 at 6:28 PM
    KBToyota
    KBToyota Well-Known Member
    Kurt
    Spotsy, Virginia
    96 Tacoma V6 4X4
    OME 883, 5100 all around, Wheelers 3 leaf progressive aal
    Master cylinder doesn't have enough volume so you have to swap i a larger one. I think the Tacoma is 1 inch one from a land-cruiser fits and is 1 1/8 and will help. I guess residual valves also help.
