Rear Brake Job on my kid's 2000 PreRunner...
Discussion in '1st Gen. Tacomas (1995-2004)' started by rzgkane, Sep 17, 2017.
  1. Sep 17, 2017 at 1:19 PM
    rzgkane
    rzgkane [OP] Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    Ok, so I go to do the brakes all around on my kid's 2000 PreRunner. I'm finishing off the rears and, as I always do, I start to clean off the axle flanges with a wire brush, my screwdriver and a high quality gasket scraper so as to create a nice mounting surface for the new drums. As I get into it it seems as if the axle flanges are entirely coated in some type of material (almost like paper or a water pump gasket) that I eventually have to completely remove in order to get to bare metal.
    What's up with this? I've never seen it before and I've done 100's of brake jobs in my lifetime. Is it some type of corrosion barrier or a replacement axle?
  2. Sep 17, 2017 at 1:25 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    It's a Toyota thing. Kinda like the sheet metal "slinger" on the back side side of the flange. I clean the gasket off and do not put one back on.
  3. Sep 17, 2017 at 1:35 PM
    rzgkane
    I figured so. Kind of a pain in the ass.
    I'm still searching for the perfect tool for cleaning these flanges that allows me to get into the tight area between the lug studs and the center bore of the axle. Maybe a small diameter wire wheel attached to a drill or Dremel? What do you guys use? Emry cloth and some hand tools takes forever, especially with the "Toyota thing" you mentioned above.
  4. Sep 17, 2017 at 1:41 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    Scrapers, thick and thin, power wire brush, a little solvent, cussing.
  5. Sep 17, 2017 at 1:45 PM
    rzgkane
    Ok, good. So I did it right.
    Dirty Pool[QUOTED] likes this.
