Rear Brake Line Problems
Discussion in 'Technical Chat' started by ToyYoda, Jun 14, 2013.
  1. Jun 14, 2013 at 12:55 PM
    ToyYoda
    ToyYoda [OP] ToyYoda
    Devin
    Cheyenne, Wyoming
    02 Tacoma SR5 TRD 4X4
    So I'm in the process of putting my suspension lift on my 02 and am having problems with the rear brake line. Im replacing it with the extended brake line, however I cant get the brake line off of the steel line where it connects with the flare nut. The old flare nut is rounded off and cant break it.
    Im looking to just get a whole new steel brake line with a good flare nut so that I can attach the new extended line.
    Does anyone have any info on how I might remove/replace the steel line? Ive looked online and searched the forum a couple times. Any help would be greatly appreciated.
  2. Jun 14, 2013 at 1:33 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    You'll need a flaring tool and a nut, needs to be the right size and right flare.
  3. Jun 14, 2013 at 5:06 PM
    ToyYoda
    Devin
    Cheyenne, Wyoming
    I thought about that, however I still need the either get the brake line off of the steel line or remove the steel line completely so I can match it to a new one that will be the correct size. Should I just try to cut the steel line and flare it with a new flare nut? or if I replace the steel line, what Im asking is how to get the steel line off.
  4. Jun 15, 2013 at 10:23 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    I was saying you could cut the line with the proper tool needed for the appropriate flaring tool, then re-flare with a new union nut and then add your extended brake lines. As long as you're able to get the other side of the soft line off, just cut off the last bit of steel line and toss the whole thing.
    Perhaps this could help.
    http://www.fedhillusa.com/?page=tech2#3
  5. Jun 16, 2013 at 10:04 AM
    ToyYoda
    Devin
    Cheyenne, Wyoming
    Thanks. I think I'll try that. I appreciate your help.
