Rear brake lines
Discussion in 'New Members' started by Wolfn69, Dec 19, 2018.
  1. Dec 19, 2018 at 2:14 PM
    Wolfn69
    Wolfn69 [OP] Active Member
    2000 Tacoma xcab Silver V6 TRD
    Lost brakes on my 2000 Tacoma. Lucky I got a 5 speed lol First problem was no fluid getting to front brakes even when bleeding. Next thing I lost total brakes pedal to the floor limped truck home. Only fluid loss i see is near or on a box above the drivers side rear tires on the frame w brake lines going in and out. What is this part exactly and is it easy to replace ..
    irayfz6 likes this.
  2. Dec 19, 2018 at 2:46 PM
    MJ-12
    MJ-12 Well-Known Member
    Tee
    Houston, Texas
    2018 Limited 4x4 Mag Grey
    Stock
    Welcome
    Check all your brake lines, was it at a fitting or the lines itself?
    Is the frame rusted? Which means the lines might be serious rotting (rusting).
    Check the “O” rings at fittings.
    Once the leak has been found, bleed the
    whole system.
    At his point, I would do a complete brake
    overhaul. But that’s just me.
    Your brakes and life depend on stopping.
    irayfz6 likes this.
  3. Dec 19, 2018 at 3:11 PM
    Wolfn69
    Yeah frame rusted in rear bad leaf spring bracjed rusted off frame she goes down road a little sideways. That a whole other problem. Only leak I see is at that box above rear on drivers side above the drum
    irayfz6 likes this.
  4. Dec 19, 2018 at 6:02 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Welcome to TacomaWorld!
    Taco critter likes this.
  5. Dec 20, 2018 at 11:52 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    When was the last time the fluid was changed?
    irayfz6 and Taco critter like this.
  6. Dec 21, 2018 at 11:37 AM
    Wolfn69
    Fixed line in rear still can't get nothing but a dribble to the front brakes I know I should start with the rear and bleed first. Bleeders are rusted in rear couldnt even move them guess just try and see what happens. I guess the main problem before the rear line rusted thru was the fluid wasnt getting to the front brakes way before the rear hole problem. What could cause that w no leaks and bleeding didnt work
    irayfz6 likes this.
  7. Dec 21, 2018 at 11:53 AM
    eon_blue
    Azusa, CA
    Welcome to TW!
    Someone has to say it...this sounds really dangerous and this combined with the brakes failing makes me wonder if this truck should even be on the road anymore...unfortunately, 1st gen Tacomas have a bad rust problem with the frames in certain parts of the country.
    irayfz6 likes this.
  8. Dec 21, 2018 at 12:22 PM
    Wolfn69
    Frame on rear pass side has been fixed about to get the bad side fixed and welded as well. I'll keep it as a farm hunting truck but need the brakes to work to be able to do so. Far cans be used as an everyday ride lol
