Rear Brake linkage
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2001convertable, Dec 31, 2022.
  1. Dec 31, 2022 at 11:48 AM
    2001convertable
    2001convertable [OP] Well-Known Member
    Anthony
    Long Island New York
    2020 tacoma, 1999 Tacoma, 1959 apache, 2014 corvette and 1982 corvette.
    Does anyone have a parts list or know how the e brake linkage above the rear differential work? I replaced both e brake levers on each side into the drums. If I pull on both cable behind the drums it applies the e brake. When I pull the e brake in the cab the passager side only applies. The cable on the drivers side does not move. What can this be? thanks
  2. Dec 31, 2022 at 12:31 PM
    02hilux
    Planet: EARTH
    pictures of your rear axle will help.
    Is the driver side cable still attached to the swivel?
    Nessal likes this.
  3. Dec 31, 2022 at 12:50 PM
    2001convertable
    Anthony
    Hi, its a 4wd. It is attached to the differential area.
  4. Dec 31, 2022 at 12:51 PM
    2001convertable
    Anthony
    does the area where the cables attach to the middle swivel?
  5. Dec 31, 2022 at 12:53 PM
    02hilux
    Planet: EARTH
    swivel should be located more on the driver side (on top of housing), next to the third member
  6. Dec 31, 2022 at 12:56 PM
    2001convertable
    Anthony
    I maybe describing this wrong.
  7. Dec 31, 2022 at 12:57 PM
    2001convertable
    Anthony
    the arm on top of the differential that both cables attach, does that move?
  8. Dec 31, 2022 at 1:38 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Yes that is a special set up that needs to be free to move.
    The upper and lower pieces a shoulder bolt 2 bushings and a lock nut. there might be some flat washers as well.
    The lock nuts just needs on the bolt not tighten up tight.
  9. Dec 31, 2022 at 2:02 PM
    2001convertable
    Anthony
    I was thinking it might be frozen.Thats why one side works and the other side not.
  10. Dec 31, 2022 at 2:08 PM
    Bivouac
    More likely just installed wrong.
    The nylon bushings should prevent it seizing . Even in the Sunny dry paradise of Long Guyland.
  11. Dec 31, 2022 at 2:39 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    pics would help
  12. Dec 31, 2022 at 4:27 PM
    2001convertable
    Anthony
    Yes, tomorrow morning. The arms at each drum were changed today. drivers side was seized. they move great now. the cable on the drivers side is the issue now.
