Rear brake locking up
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Al2642, Sep 3, 2019.
  1. Sep 3, 2019 at 6:42 AM
    Al2642
    Al2642 [OP] Member
    Al
    California
    Anyone experiencing the same problem I'm experiencing? I'm having a problem with my 2017 Tacoma, when I wash the vehicle, the rear brake on the driver side locks up when I try to pull away. Only the passenger side tire will spin dragging the driver side tire. I've been to Toyota several times and they can't find an issue with it. The last time I was there, they replaced everything on the rear brake parts. Washed my truck yesterday and it happened again. Luckily I have video proof to show them or they'd think I'm crazy.
  2. Sep 3, 2019 at 6:46 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    It happens. Normally associated with a vehicle that has been washed and then sat overnight, or for a period of time with the parking brake engaged.
    Haven't heard of it with a wash n' go, though.
  3. Sep 3, 2019 at 6:46 AM
    7D2Nova
    7D2Nova Active Member
    Bryce
    2018 Cement TRD Off-road
    I’ve had a similar thing happen on my 2018 after I wash it and it sits overnight. Not sure which wheel it is on mine. Thought it might be the front cuz once it stuck bad enough that it spun the rear tire before it broke loose.
    I’ll definitely watch this thread to see what you figure out!
  4. Sep 3, 2019 at 6:48 AM
    Boss hoss
    Boss hoss Well-Known Member
    Richard
    Silverton Oregon
    2021 TRD OR premium access cab.
    Carpet bed liner and Matt, fuel wheels KO 2 tires. Bilstein 6112,5160 frt. lift .white with black leather seats.
    Sounds like a parking brake hanging up.
  5. Sep 3, 2019 at 7:11 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Are you moving the truck immedately after you wash it? Or is it staying parked for an extended period of time? I've never had this happen to me (summer or winter) but have heard of it happening with others. Have you tried to drive it around the block or down the street to get the water out and dry it up?
    shakerhood likes this.
  6. Sep 3, 2019 at 7:14 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Sounds like water is getting into the drum and rusting the shoe to the braking surface.
  7. Sep 3, 2019 at 9:47 PM
    Al2642
    Al2642 [OP] Member
    Al
    California
    No , not usually. I'll try doing that before I dry the truck off. Thanks
  8. Sep 4, 2019 at 8:39 AM
    Tacowin1013
    I usually take it around the block and back in the driveway after i dry it and before i start the wax/sealant process
  9. Sep 4, 2019 at 8:47 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I'm not having this issue, but have seen it with my previous truck after I changed the shoes from OEM to Centric. I just chalked it up to a different shoe compound that maybe swells temporarily with water.
    Are you washing on a level surface? If safe to do so, leave the parking brake off when washing the truck.
    Lucifer1 likes this.
