Rear brake problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by rhilton, Nov 27, 2010.
  1. Nov 27, 2010 at 2:30 PM
    rhilton
    rhilton [OP] Member
    rob
    Long Beach, CA
    2002 TRD Sports
    none DD
    i have a 95.5 ex cab.
    I have very little rear braking, 127k and the rear shoes are only warn about 50%. I would like to install a different
    proportioning valve or adjust the one that's there better.
  2. Nov 27, 2010 at 2:36 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2010 Double cab 4X4 TRD Sport with JBL
    Redline Tuning hood struts, tinted windows, FX-R HID projector retrofit headlights, AMP power steps
    No, that is not a problem. My 96 had 120,000 miles on it and hardly show any wear. You're fine.
  3. Nov 27, 2010 at 4:15 PM
    thatSchusterguy
    thatSchusterguy Common Sense Ninja
    Cincinnati, OH
    96 X-Cab
    OME/881 Downey Shackles Bilstein 5125's Demello HD sliders Marlin 1200# Clutch
    You might need to clean & adjust them if you have little rear braking power...but why the hell would you replace something when its 50% worn?
  4. Nov 27, 2010 at 6:34 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    I don't remember if our trucks use an adjustment screw, but those like to get gummed up and stop expanding to adjust for shoe wear. Either way, clean everything and use 3m caliper guide pin lube on the screw and anchor points.
    Don't change the valve. Locking rear brakes are BAD;)
  5. Nov 27, 2010 at 6:52 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    You can adjust the arm that comes out of the BPV in the upward direction to slightly increase the rear braking. Be aware that doing so reduces front braking by an equal amount. Consider a small adjustment (1/4") to start, to see how it feels. A 1/2" adjustment will significantly impact the braking balance and could cause your rear tires to lock up before your fronts, under hard braking.
  6. Nov 27, 2010 at 7:18 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    That's an option to consider after you rule out the brakes themselves being the problem.
  7. Nov 28, 2010 at 11:35 AM
    rhilton
    rhilton [OP] Member
    rob
    Long Beach, CA
    2002 TRD Sports
    none DD
    My 95.5 Tacoma dose not have ABS Brakes.
    The rear brakes are adjusted to the point that they drag just a little.
    On hard braking the front discs lock up and leave flat spots on the front tires. The rear tires never leave skid marks. someone has adjusted the shackle length about 1/2" shorter ( Dealer ?), but this hasn't helped .I read that rock climbers tend to remove the stock Proportioning valve and
    install an adjustable proportioning valve, so they can get more pressure to the rear brakes. Haven't been able to find a wright up on this mod, anyone find info on this mod?
    The original Toyota Pads went 18,000 Miles, the Auto zone pads go about 3500 miles.
  8. Nov 28, 2010 at 8:18 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Hope that is a typo. If you only get 1,800 miles out of a set of toyota front brake pads, you got bigger issues going on than braking proportioning.
  9. Nov 29, 2010 at 9:58 PM
    jvallin
    jvallin Well-Known Member
    joey
    turlock CA
    01 Dcab SR5 4x4
    K&N intake, Magnaflow, HID conversion, 265/75/16 MT, PIAA driving lights, Optima red top, billstein 5100's @ 2.5 and pro comp 2" AAL.
    This is normal for the rear brakes on a truck. Just had to replace mine at 200,000. Trucks dont use alot of braking power in the rear since there is no weight back there usually.
  10. Nov 29, 2010 at 11:28 PM
    Whitfield
    Whitfield Well-Known Member
    Central Virginia
    99 TRD X-cab on 35's / 96 X-cab on 33's
    Selling my 96 Tacoma to fund the FJ80 build up.
    All good info other then the arm direction...
    You adjust it up for more braking. The design is to push the arm up for more rear brake bias when the bed is loaded. You can remove the arm from the axle and strap it to the bottom of the bed for full rear bias to play around with the extreems and then adjust it to your tase. Just be fore warned that an unloaded pick up will lock the rear fast in slick conditions. This can cause loss of control and Toyota has spent lots of engineeering dollars for design safety. Once you go tampering with it you are out on a limb.
  11. Nov 30, 2010 at 10:08 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
  12. Nov 30, 2010 at 11:33 AM
    Whitfield
    Central Virginia
  13. Nov 30, 2010 at 12:47 PM
    Flash1034
    Flash1034 Well-Known Member
    Southern California
    2003 SR5 TRD 4x4 Extracab 3.4 liter
    None
    Can you guys confirm that the rear brake adjusters get turned clockwise if you are looking at the truck from rear to front?
    Flash
  14. Nov 30, 2010 at 6:23 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    They both turn opposite each other. The easiest way to figure out which way they move is to remove the drum.
  15. Nov 30, 2010 at 9:15 PM
    Flash1034
    Southern California
    None
    So Right rear turns up and left rear turns down?
    Flash
  16. Nov 30, 2010 at 9:29 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Opps! You are correct Sirs! Thanks for catching that. I've corrected the info in post #6
  17. Dec 1, 2010 at 2:55 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    I don't remember. That's why I suggested pulling the drums. The adjusters are probably frozen and need cleaned and lubed. You don't have to dissassemble the whole assy. Just pry out the adjuster.
  18. Dec 1, 2010 at 10:50 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Usually when you go to adjust them with a brake spoon, they will turn one direction fairly easy and the other direction is hard to turn them. The direction that they turn easy is the direction that adjust them up correctly. Pretty simple.
