Rear Brake Proportion Valve
Discussion in '2nd Gen. Tacomas (2005-2015)' started by charlesbrandon86, Apr 26, 2017.
  1. Apr 26, 2017 at 5:37 PM
    charlesbrandon86
    charlesbrandon86 [OP] Active Member
    Does anybody know if there is a way to adjust the brake proportion valve? Is there even on present on the 2nd gen or is all controlled via some computer?
    I recently purchased my SAS'd DCab and had to slam on brakes today. The fronts did not lock up but the rear did. I was still able to control the stop although I am sure it looked scary from behind.
    I am hoping to take some of the hydraulic pressure from the rear and keep it towards the front.
  2. Apr 26, 2017 at 5:39 PM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    Buy a wilwood porportioning valve and plumb it in the rear line
    charlesbrandon86[OP] likes this.
  3. Apr 26, 2017 at 5:41 PM
    charlesbrandon86
    thanks for the advice
  4. Apr 26, 2017 at 5:51 PM
    charlesbrandon86
    We have a brake line for each wheel which means I would need two of them correct? One per wheel and then adjust as necessary...
  5. Apr 26, 2017 at 5:56 PM
    Basikbiker
    Trav
    Nah just Tee the two separate lines to one, then porportioning valve and cap the unused line
  6. Apr 26, 2017 at 5:58 PM
    Basikbiker
    Trav
    Since it's already solid swapped it's easy to get rid of the abs module
