Rear Brake Shoe Life??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bruce1271, Nov 30, 2009.
  1. Nov 30, 2009 at 12:45 PM
    bruce1271
    bruce1271 [OP] Well-Known Member
    Guys,
    I got 60k on my first set of pads. I am at 92k now and thinking of my shoes. I need to have a look, but what mileage is everyone seeing for their rear shoes lasting?
  2. Nov 30, 2009 at 12:55 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    i would like to be able to tell you but i have never worn out a set of shoes,looked @ mine at 50 k still looked brand new.
  3. Feb 19, 2012 at 10:40 PM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    Good question
  4. Feb 19, 2012 at 10:43 PM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    Working on many tacomas and 4runners, I would regularly see the shoes go 100k+ with normal use. My personal 4runner went 165k before the shoes needed replacement. I replaced them more often from damage due to leaking axle seals than actual wear. Unless of course it was driven with the parking brake on or regular towing etc.
    The rears only do about 30% of braking duty, so the shoes do not require replacement until they are at 1.5mm-2mm.
  5. Feb 19, 2012 at 10:46 PM
    Fractured
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    Wheels don't always have to be pulled, there is a little round rubber plug on the backing plate that will allow you to see how much meat is on the shoe. It is just to be meant for a quick check, and will not show you the status of the wheel cylinders, axle seals etc. you WOULD need to remove the wheel for that.
  6. Feb 19, 2012 at 10:55 PM
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
    Have 90k on mine. Getting my fronts replaced, should get the routers done but waiting to replace them. Drums have 50% left. Just need light maintainance, cleaning.
  7. Feb 20, 2012 at 6:16 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Depends where you live cities will ware them out faster then the willie wags towing and heave loads too. My 97 had 248K and never had rear brakes and it wasn't because they were never look at, had the drums off 3 times to fix the hanging parking brake pins. Pickups are light in the back end the rear brakes don't get much use the front does most of the stopping.
  8. Feb 20, 2012 at 6:20 AM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    I replaced mine on my 06 @ 60k. Probably could have gone farther, but they're cheap.
  9. Feb 20, 2012 at 6:38 AM
    4wd Boss
    4wd Boss Shake and Bake
    Jefferson
    Big D
    16 Quiksand TRD Offroad
    Fog Light Mod, Pro Grille, raptor lights, 1.25 spacers, RC coilovers
    all of our toyota vehicles at work (tacoma, Siena, matrix) have exceeded 100K on rear pads. either toyota makes really good quality pads or normal braking just doesnt really wear them down.
  10. Jul 11, 2016 at 8:34 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Bring this up from the grave...
    171k miles
    eherlihy likes this.
