Rear brakes? Auto adjust?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mr.Gadget, Feb 4, 2013.
  1. Feb 4, 2013 at 11:26 AM
    Mr.Gadget
    Mr.Gadget [OP] Well-Known Member
    NC
    2011 DC 4x4 SR5 SB/2012 DC 4x4 SR5 LB(sold)
    Rear brakes on these trucks, are they auto adjust like a lot of others.
    I remember a few posts people not liking the rear drum brakes and you needed to adjust them all the time.
    Mine have been fine and working like they should and I tow a lot.
    Most all the newer trucks that still use drums have a adjustment lever that works when backing or the Ebrake is used.
    Anyone have info on these?
  2. Feb 4, 2013 at 11:36 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    yes they auto adjust
    if they are 'normal' and just need to take up slack:
    roll backward a bit, engage e-brake to stop
    repeat until adjusted
  3. Feb 4, 2013 at 11:43 AM
    Mr.Gadget
    NC
    That was what I was thinking but several have said that they are a PITA to adjust.
    I always back in at the house and work and always use the E brake so have not has a problem as of yet.
  4. Feb 4, 2013 at 12:48 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    well, if the cables are stretched, then they are a PIA to adjust
    you gotta climb under it and monkey with the cable hangers and take ups
    but for normal cables, just pad wear,
    a) if you use the parking brake daily, they will always auto adjust
    as the brakes will never be more than one click out
    b) if you use the parking brake rarely, the backup procedure should do it
    backup procedure can reel in about 3+ clicks on the adjuster at a time, so
    even with 12 clicks out, 4 or 5 reverse brake procedures can take up slack
    if none of this works, time to pop the drums, take a looky and manually crank the adjuster
    SR-71A likes this.
  5. Feb 4, 2013 at 5:18 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    127.0.0.1 is quite correct. Everyone that adjusts their rear brakes do not know what they are talking about. They should only need to be adjusted once when the rear shoes are replaced.
  6. May 20, 2014 at 6:31 PM
    TacomaTRD4x402
    TacomaTRD4x402 Well-Known Member
    So Cal
    '02 Tacoma TRD 4WD 3.4 5spd S/C Long Travel
    Ok I JUST replaced my rear shoes and wheel cylinders on my taco, i'm kinda gettin different ways of adjusting them. one video i saw says start at zero point, then put the drum on and click just once than spin, click again than spin, over and over until i hear the shoes rubbing the drum. IS this the best way?
  7. May 20, 2014 at 8:45 PM
    TacomaTRD4x402
    So Cal
    Alright well I just finished changing out my rear brakes and even installed new wheel cylinders. Like i said in previous post, i set the adjuster to zero and started adjusting than spinning till i heard the shoe rub the drum. oddly thought the drivers side didn't need adjusting :confused:
    well i put everything back together and started the backward driving as said in other posts and kept pulling the ebrake, nothing was happening. i did it about 30 or 40x's! and the cable just pulls, thats all. truck doesnt even stop. Am i forgetting something?
    Also, i did feel like i lost a lot of braking power just from my pedal, could this be because i swapped out both wheel cylinders? and now i have to bleed my system?
  8. May 20, 2014 at 8:51 PM
    gearcruncher
    Canadain bumper technician
    YES ... need to bleed rear brakes
  9. May 20, 2014 at 9:04 PM
    TacomaTRD4x402
    So Cal
    Would that also affect why the parking brake is not engaging as well?
  10. May 20, 2014 at 9:15 PM
    gearcruncher
    I would start by bleeding the rear brakes as highest priority . When you replaced the wheel cylinders , you must have lost all kinds of brake fluid . Now there is a bunch of air in the system .
    For the E-brake , Its there should one of your wheel cylinders fail .With this said the e brake should work without the use of hydraulics .
    The only issue I can see is when you use the parking brake without bleeding the wheel cylinders becuase the wheel cylinders are used as a pivot point and the e brake expects tension from the wheel cylinder push rods .If you have a bunch of air in the rear wheel cylinders , you may not get all the e braking , you normally would if the wheel cylinders were bled properly
    Edit " after looking at the Tacoma drum design , your e brakes should work properly without the cylinders working .
    Here is an image http://www.tacomahq.com/1668/toyota-tacoma-drum-brakes-last-long/
    SR-71A likes this.
  11. May 20, 2014 at 9:22 PM
    TacomaTRD4x402
    So Cal
    Awesome! Thanks so much for the info! So that's what' i'll do than. :thumbsup:
  12. May 21, 2014 at 8:25 PM
    TacomaTRD4x402
    So Cal
    So I went n bled my brakes today and my parking brake still is not engaging properly. Also my regular brakes seem to not be working very well either. This is all after changing my rear brakes, along with both wheel cylinders.
    Also note, when i put the drivers side drum on, the shoes seemed to already be slightly rubbing against the drum so I left the star adjuster all the way tightened. Could this be the problem? If so, that wouldn't explain my regular brakes being so squishy, would it?
    Any advice please?
  13. May 21, 2014 at 8:44 PM
    Toyoland66
    Toyoland66 Well-Known Member
    Colorado
    09 GX470
    Mostly stock on 35s
    Bleeding brakes will have zero effect on the parking brake. The parking brake is cable actuated.
    Make sure you bleed your brakes in order of what cylinder is furthest from the master cylinder to closest. Also if there is a lspv (don't recall if first gens have them) that may need to be bled as well.
  14. May 21, 2014 at 9:02 PM
    TacomaTRD4x402
    So Cal
    Yeah, I bled them in the correct order. Also i did bleed the lspv as well.
    So the parking brake is not related to the hydraulic system at all? What about the star adjuster? i'm thinking if i go back in and adjust the rear brakes some more, that might help. i'll try this again tomorrow.
  15. May 21, 2014 at 9:05 PM
    TacomaTRD4x402
    So Cal
    Also, i JUST realized im treading in the 2nd gen forums. Didn't even realize till you had mentioned 1st gen.
    So is it safe to assume my truck is self/auto adjusting as well?
  16. May 21, 2014 at 9:53 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    In my opinion the self adjusters are too loose. This will effect the hydraulic brakes.
    I think you need to follow the field service manual which says:
    ADJUST REAR DRUM BRAKE SHOE CLEARANCE
    (a) Provisionally install the hub nuts.
    (b) Remove the hole plug, and turn the adjuster to expand the shoe until the drum locks.
    (c) Using a screwdriver, release the adjuster 15 notches.
    (d) Install the hole plug.
    You probably do not need to adjust the cable if it was fine before you replaced the brakes. Do the above adjustment first, then adjust the parking brake handle if needed:
    INSPECT PARKING BRAKE PEDAL TRAVEL (for Automatic Transmission)
    (a) Slowly depress the parking brake pedal to the fully applied position, and count the number of clicks. Parking brake pedal travel at 300 N (31 kgf, 67 lbf): 7 to 10 clicks
    INSPECT PARKING BRAKE LEVER TRAVEL (for Manual Transmission)
    (a) Slowly pull the parking brake lever to the fully applied position, and count the number of clicks. Parking brake lever travel at 200 N (20 kgf, 45 lbf): 7 to 10 clicks
    6. REMOVE CONSOLE UPPER REAR PANEL SUBASSEMBLY (for Automatic Transmission on Separate Seat Type) (See page IP-9)
    7. REMOVE CONSOLE UPPER REAR PANEL SUBASSEMBLY (for Manual Transmission on Separate Seat
    8. REMOVE CONSOLE BOX ASSEMBLY REAR (for Separate Seat Type) (See page IP-10)
    9. REMOVE PARKING BRAKE CABLE JOINT PROTECTOR (for Bench Seat Type) (a) Slide the seat to the rearmost position.
    (b) Pull up the floor carpet around the cable joint protector, along its seams.
    (c) Remove the 3 bolts and parking brake cable joint protector.
    ADJUST PARKING BRAKE PEDAL TRAVEL (for Automatic Transmission)
    (a) Confirm that the parking brake pedal is released.
    (b) Loosen the lock nut and turn the adjusting nut until the parking brake pedal travel is corrected to the specified value. 7 to 10 clicks
    (c) Tighten the lock nut. Torque: 13 N*m (127 kgf*cm, 9 ft.*lbf)
    (d) Check whether the parking brake drags or not.
    (e) When operating the parking brake pedal, check that the parking brake pedal indicator light comes on.
    ADJUST PARKING BRAKE LEVER TRAVEL (for Manual Transmission)
    (a) Confirm that the parking brake lever is released.
    (b) Loosen the lock nut and turn the adjusting nut until the parking brake lever travel is corrected to the specified value. 7 to 10 clicks
    (e) When operating the parking brake lever, check that the parking brake lever indicator light comes on.
    a400ryan, lo2hi and SR-71A like this.
  17. May 21, 2014 at 9:57 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    :eek:
    You replaced your wheel cylinders and didn't bleed the system?
    DO NOT DRIVE THE TRUCK!!!!!!!!!!!!!!!
    Check your master cylinder, if it is empty, you pushed air into the ABS unit and it is going to need to go to the shop to be bled.
  18. May 22, 2014 at 2:33 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Since you're talking about a 1st gen....If you haven't already done it.....You might want to check the parking brake cable adjustment. Check all your linkages/cables.
    Here's a writeup. My 96 tacoma needed adjustment.
    http://www.lieblweb.com/ebrakeadjustment.html
  19. May 22, 2014 at 6:44 AM
    TacomaTRD4x402
    So Cal
    Thanks guys and ladies for the responses, will report back later this evening when I get to work on my truck.
    And as for driving the truck, i'm not driving it without proper working brakes, that would just be crazy haha, just testing the brakes in my garage and driveway
  20. May 26, 2014 at 10:17 PM
    TacomaTRD4x402
    So Cal
    Just wanted to update the thread. Turned out to definitely be the star adjusters. Had to adjust them till the drum wouldn't spin than go back a few clicks. Did this on both sides and now I have perfectly working brakes. Thanks all for your advice.
    lo2hi likes this.
