Rear brakes job, adjustments, and E brake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cdex8357, Jan 14, 2021.
  1. Jan 14, 2021 at 7:27 PM
    cdex8357
    cdex8357 [OP] “Everybody gotta die sometime”
    “Dex”
    H-Town
    2013 Taco OR
    Mid travel FOX 2.5 Coilovers FOX 2.5 secondary bypass FOX 12” Triple Bypass
    I just did my rear brakes, I replaced the shoes and drums.. and new hardware.
    Truck has 45k and this is the first time they’ve been replaced.
    I adjusted them and they feel great. But now my E brake won’t hold the truck.
    I tightened it under the center console and adjusted the brakes. This helped along with setting them in on a drive around town.
    Am I doing something wrong? Help me out here
  2. Jan 14, 2021 at 7:30 PM
    Bishop84
    Bishop84 Well-Known Member
    New shoes tend to have high spots that wear off quickly, simply readjust them again to have drag.
    The ebrake housing tends to break as they exit the back of the drum, it can make them weaker. It won't stop it from working but can affect operation.
  3. Jan 14, 2021 at 7:40 PM
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
    E brake housing being the part under the center console? It looks good.
    I have never done drum brakes on a Tacoma only on my Corolla I had years ago. It always a pain.
    When adjusting, how much drag? Should it be a consistent drag, or a intermittent drag, or moderate drag where the wheel does not move easy?
  4. Jan 14, 2021 at 7:40 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    6 gearT444E likes this.
  5. Jan 14, 2021 at 7:41 PM
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
    i did this, didn’t work. Tedious.
    llamasmurf likes this.
  6. Jan 14, 2021 at 7:57 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Adjust until a light drag. Tighten up on the adjuster nuts under the console.
  7. Jan 14, 2021 at 8:00 PM
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
    I did this and got it to stick.. but it’s not a strong e brake engagement
  8. Jan 14, 2021 at 8:03 PM
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
    Some videos on YouTube say light drag and other say heavy drag. Where it’s tuff to turn and let the brakes wear in. When I took the drum it was tuff to turn and take off. Confusing.
    I replaced the wheel cylinder cause there’s was some oil around the boot, Rear passenger Side.
  9. Jan 14, 2021 at 8:10 PM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    I have 140k and I’m still on the original rear brakes.... Only my second set of fronts. What are you all doing to your poor brake pedals?
  10. Jan 14, 2021 at 9:27 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I would recheck the drag, after replacement it can take several adjustments before the auto adjuster will be effective I’ve found.
  11. Jan 15, 2021 at 4:44 AM
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
    I was putting extended studs and just decided to replace the shoes. Then chased the rabbit and got new drums.
    Accipiter13[QUOTED] likes this.
  12. Jan 15, 2021 at 11:23 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    The Rabbit always wins when he goes down the rabbit hole....
  13. Jan 15, 2021 at 12:00 PM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    I remember 3rd gen 4runners had the trick where you roll the truck backwards and pull the e brake to adjust and tighten the rear brakes. does this work on Tacomas too?
    Marc70 likes this.
  14. Jan 15, 2021 at 12:04 PM
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
    I don’t think so.. but shit I’ll try it
  15. Jan 15, 2021 at 12:14 PM
    Sae68
    Sae68 Well-Known Member
    JimS
    Stockton, CA
    05 FJ 4x4 PreRunner
    Most likely rear brakes need to be adjust.
    make sure drums is fully seatted adjust my til feel slight drag.
  16. Jan 15, 2021 at 12:16 PM
    forana
    Kaneohe, Hawaii
    I'm not saying to try it! Just a wondering...
  17. Jan 15, 2021 at 12:17 PM
    forana
    Kaneohe, Hawaii
  18. Jan 15, 2021 at 12:18 PM
    forana
    Kaneohe, Hawaii
    3rd gen 4runners were so great. Except for the undersized front brakes and crap ass rear brakes. Burned so many rotors.
  19. Jan 15, 2021 at 1:34 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Did I see that right 45k. Why did you you replace them. No way they were worn out.
    vtown and Jimmyh like this.
  20. Jan 15, 2021 at 1:37 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    The Rabbit made him do it.
    :rofl:
