Rear brakes locked up
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dave3359, Jul 14, 2019.
  1. Jul 14, 2019 at 1:35 PM
    Dave3359
    Dave3359 [OP] Well-Known Member
    Dave
    Fl
    2018 Blazing blue access cab
    came out this morning to move my truck released the emergency brake and put in drive truck would not move gave it more gas right rear tire started to spin and burn rubber. Driver side locked and not moving put it in 4 hi truck started to move went about 50 feet ( diver side still lock up) then a little forward then reverse and pop it finally let go. All I did the day before was wash the truck and then park it. Any clues as to what’s going on if it was winter no question frozen brakes but it’s 95 degrees here.
  2. Jul 14, 2019 at 1:38 PM
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    Road salt in your area? Brake cable or linkage stuck possibly.
  3. Jul 14, 2019 at 1:38 PM
    TacoRated
    TacoRated Do the chickens have large talons?
    Colorado
    2016 DCSB TRD OR
    High speed, special purpose duct-tape noise cancellation LCAs. Redline Tuning hood struts Hefty Fabworks Rock Sliders Trifold Bed Cover TRD Pro Grille
    This happened to another guy recently. Is your truck lifted?
    FishnTx, whatstcp and Boghog1 like this.
  4. Jul 14, 2019 at 1:55 PM
    Dave3359
    Dave
    Fl
    No salt 8k on for mileage and 100 % stock
  5. Jul 14, 2019 at 2:07 PM
    trazerr
    trazerr Well-Known Member
    Oregon
    2024 Tundra Plat 4x4 LB (prev 2018 DCLB SR5 4x4 and 1996 AC LX 4x4 5sp)
    quite a few threads on here about this issue. Got to drive these trucks some after washing otherwise the above can happen.
  6. Jul 14, 2019 at 2:09 PM
    Bishop84
    Bishop84 Well-Known Member
    Rust build up in the drums, it happens but not very often.
    Tacos4ever15 likes this.
  7. Jul 14, 2019 at 2:12 PM
    Dave3359
    Dave
    Fl
    Still some water in the drum over night should not lock the rear drum up like that.
  8. Jul 14, 2019 at 2:15 PM
    trazerr
    Oregon
    It shouldn’t but it’s happened some on here. Mine popped once but it didn’t stick like yours and others have. I try to drive mine real quick after a wash if I remember to though.
  9. Jul 14, 2019 at 2:24 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    It's the drum/emergency brake seized up, had it happen to my fiances civic, either put a 2x2 against the drum and hit it with a large hammer to jar them loose or drive it for about 20 feet and itll poop loose.
    Solution - Dont put the parking break on after getting the rear brakes really wet.
  10. Jul 14, 2019 at 2:27 PM
    Dave3359
    Dave
    Fl
    I guess I can do that. I’m going to take the drums off tomorrow and see what he’ll is going on and if need be will lubricate and clean.
  11. Jul 14, 2019 at 2:41 PM
    TacoBella
    TacoBella Well-Known Member
    Tom
    2016 Tacoma (SOLD) leased RTL-E Ridgeline
    AVS Bug Deflector. TruXedo Lo Pro
    Tacoma definitely needs to get rid of those drum brakes and step into the 21st Century. No more excuses
  12. Jul 14, 2019 at 2:46 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Advantages of Drums:
    • Efficiency: Greater torque production at a given line pressure for same diameter drum vs. disc. This is why the disc is almost always larger diameter than the drum it replaces on cars that could have either brake system. The larger disc diameter is needed for adequate torque production.
    • Weight: Drum systems weigh less than comparable disc systems.
    • Parking Brake: Drum brakes make a superior park brake due to the wedging action of the shoe against the drum. Once the park brake is set, any attempt to rotate the wheel causes the drum brake to grip harder (like a wedge type door stop).
    • Drag: Much time is spent designing systems that will pull the pads away from the disc to minimize energy loss due to pad drag on the rotor. In a drum brake system, springs pull the shoes away from the drum so that, at normal operating temperatures, there is little or no brake drag. I think I would argue that drums have a higher loss than disc due to how they’re typically adjusted. But if adjusted correctly, there should be slight drag when cold, but as the drum heats and expands, drag is reduced, or is it negligible?
  13. Jul 14, 2019 at 2:49 PM
    TacoBella
    Tom
    Not convinced. The disc brake has its own advantages and one of them is easy inspection. The disc brake system also has better stopping power than the drum brake. And THATS why we even have brakes.......to stop. Now.
    THIS is why Toyota still uses drums...Drum brakes are cheaper to manufacture than disc brakes, because there are fewer moving parts and because in the rear the parking brake (which often works by an drum-and-shoe mechanism even on four-wheel-disc-equipped cars) can share a drum with the "regular" brakes. It's not about stopping power, It's about Toyota saving money.
  14. Jul 14, 2019 at 2:58 PM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    Was the parking brake set when you washed it and left engaged overnight? If so it might have caused the shoes to rust to the drum. Best thing to do is drive it for a bit after washing to clear the water from the surfaces or else just leave the parking brake disengaged overnight.
    As for the disc vs drum brakes, I've had 5 trucks in 33 years, many times have had to replace either pads and rotors. Not once have I had to do anything other than one or two minor adjustments to the rear drums.
    Drum brakes can seize in the winter, I just don't use the parking brake in sub freezing temps.
    jquest71 and TacoBella like this.
  15. Jul 14, 2019 at 4:54 PM
    Dave3359
    Dave
    Fl
    Yes brake was set when I washed it then I moved the truck around and parked it for the day and set the e brake. I have done this same procedure countless times and never had this happen.
  16. Jul 14, 2019 at 4:58 PM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    How far is "move the truck around"?
  17. Jul 14, 2019 at 5:00 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Do you have an AAL or aftermarket leafsprings?
  18. Jul 14, 2019 at 5:00 PM
    Dave3359
    Dave
    Fl
    Not to far maybe a couple hundred feet
  19. Jul 14, 2019 at 5:01 PM
    Dave3359
    Dave
    Fl
    Nothing the truck has 8k miles and stock suspension
  20. Jul 14, 2019 at 5:04 PM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    That's probably not going to clear out the water, I'd drive it a few miles and cycle the brakes a couple of times.
    Or just leave the parking brake off overnight after washing.
