Rear Brakes Maintenance?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bmw2Taco, May 17, 2024.
  1. May 17, 2024 at 5:48 PM
    Bmw2Taco
    Bmw2Taco [OP] Well-Known Member
    2018 Blue 4x4 TRD Sport Premium
    2018 Sport with 70k miles. When should I service my rear brakes? Is there a good write up or YouTube link?
  2. May 17, 2024 at 5:52 PM
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    Service them when they need it aka worn out
    I-Give-Up likes this.
  3. May 17, 2024 at 6:04 PM
    Bmw2Taco
    Considering they're hidden by the drum and can't be visually inspected..what's the typical life span?
  4. May 17, 2024 at 6:09 PM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    I never had to service mine in 145000 miles. Just pull the drums and look at the shoe material thickness next time you rotate the tires.
    Replacement recommendation is in the manual, but it's some around 2 mm remaining.
    Edit: I only replaced the front pads once, i want to say around 110k, so you have a reference for driving style.
    ryanvar42 likes this.
  5. May 17, 2024 at 6:11 PM
    Bmw2Taco
    Thanks for taking the time to reply in a helpful manner!
    mquibble, RotorRPM and TacoManOne like this.
  6. May 17, 2024 at 6:13 PM
    Schlappesepple
    Joe
    2020 4Runner ORP
    The other key advice for doing drums is take a few pictures before you take it all apart. And do one side at a time so you have an intact reference. But I'd be surprised if you had to do that anytime soon.
    mquibble, Chew and Bmw2Taco[OP] like this.
  7. May 17, 2024 at 6:17 PM
    Bishop84
    Bishop84 Well-Known Member
    They should be adjusted at least 2 times a year, typically during a rotation.
    You dont need to do much, they arent lubricated much from factory. Just remove drum, remove the dust with brake cleaner, then adjust the star wheel until drum has a slight bit of drag.
    Drums can last a long time, but are far more effective when adjusted. Typically rear brakes should last about 100,000 miles if maintained.
    If they arent adjusted they can last the lifetime of the vehicle.
    joba27n, b_r_o and RustyGreen like this.
  8. May 17, 2024 at 6:20 PM
    JackieDaytona
    JackieDaytona Well-Known Member
    2016 inferno sr5
    In progress
    Rear drums typically last a very long time, one of my last cars had 225k miles and the rear drum never had to be serviced.
  9. May 17, 2024 at 6:25 PM
    Bmw2Taco
    I understand that drums can last a very long time but the lifetime of the shoes is of course much shorter. My concern is the shoes, not the drums. Regardless, based on feedback, I don't need to be concerned for quite a while.
  10. May 17, 2024 at 6:27 PM
    Bishop84
    Sorry I got loose on the lingo, often we refer them as "drum brakes", 100,000 is for shoes and drums.
    RustyGreen likes this.
  11. May 17, 2024 at 6:29 PM
    Bmw2Taco
    No worries. I'm itching for something to work on, but it looks l need to keep itching. Thanks again!
  12. May 17, 2024 at 6:44 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Swing by my place, there is so much to do you will think you have fleas... :laugh:
    mquibble and Phlogiston like this.
  13. May 17, 2024 at 6:47 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Pretty easy to check your rear drums. Check out this video.
    https://www.youtube.com/watch?v=-dmUF5hbQEQ
    MGMDesertTaco likes this.
  14. May 17, 2024 at 7:09 PM
    Schlappesepple
    Joe
    2020 4Runner ORP
    How well does regular use of the parking brake work to keep them adjusted?
    I never adjusted mine, but from the pad wear they were doing something when I hit the brakes.
  15. May 17, 2024 at 7:10 PM
    MGMDesertTaco
    Mine are squealing like a pig when slow parking lot braking. What brake grease is everyone using for the contact points? I don't like anti seize for that purpose.
  16. May 17, 2024 at 7:27 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    How's the parking brake work? Does it set firmly? Does it go all the way to the carpet?
    Honestly that's the quickest way to get a window into the health of the system
    Don't expect the self adjuster to work properly, they never do.
    After the shoes are clean and snug there's an adjustment up in the cabin for the cable when it stretches
  17. May 17, 2024 at 8:09 PM
    I-Give-Up
    I-Give-Up Well-Known Member
    West Phoenix, AZ
    2023 Ice Cap Tacoma TRD
    Meso spare fuse holder. Aluminum gas cap holder. Genuine Toyota bed lights. Bed molle racks. Ammo case storage under hood. In-bed spare tire. Automatic underhood lights. Gooey glurp on frame.
    How long do brake shoes or pads last? That's like asking how much a new car costs. Kia or Rolls-Royce?
    It all depends on the kind of driving you do. A friend in Wyoming has a 2014 Subaru with more then 220,000 miles on the odometer. She has never had to replace any of the brake pads. Her driving, once she leaves the end of her 2 mile driveway, consists of 60 miles each way without touching the brakes. Other people who live in urban areas where there's a traffic light every 1/2 mile and on a good day, only one stop per light is needed, will need replace shoes or pads much more frequently. How much more frequently? Driving style matters.
    Disc brake pads have steel flanges that make a screeching sound when they get to a given thin-ness. They will even screech when the brakes aren't being used. Drum brakes, such as on the rear of our Tacomas, need to be inspected. Excess "pull" on the parking brake is usually a clue that an inspection is needed. Disclaimer: This is based on many miles with vehicles that were not Tacomas, but the concept should be the same.
    IronratPR likes this.
  18. May 17, 2024 at 8:16 PM
    TA2016
    Oregon
  19. May 17, 2024 at 8:24 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    If it helps: once they are finally gone, (actual brake shoe linings) you'll know: they'll make a lot of very cringe-worthy/ominous grinding noises that you won't be able to ignore. :eek: "Fingernails on a chalkboard type noises..." Except maybe worse-sounding... Ya.
  20. May 17, 2024 at 10:45 PM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    It depends on driving style. I’ve owned 3 tacomas and a hilux 92. I never replaced or touched the pads. Each vehicle goes over 180,000 miles with mixed driving. I like to back off the parking brake and pull the drums to clean/inspect/lube every 5 years though. It certainly isn’t necessary.
