Rear Brakes Maintenance?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bmw2Taco, May 17, 2024.
  1. May 18, 2024 at 3:17 AM
    C-Rok275
    C-Rok275 Well-Known Member
    2017 TRD Pro
    6112/5160s with Icon stage 2 leaf’s.
    I had to replace my rear brakes around 60k, which seems way too early. The friction material was paper thin and they were starting to squeak.
    Definitely take a before picture and use the right tools.
    Today is front brakes, they’ve made it to 104k and could probably go a bit more, but the rotors are glazed.
  2. May 18, 2024 at 4:20 AM
    Pungo1
    Pungo1 Well-Known Member
    Mark
    ^^^^THIS is some of the best advice ever and it applies to almost any kind of borderline "complicated" maintenance you can do on anything these days. Cell phone cameras are awesome. Even better when you always think in terms of having a backup.
  3. May 18, 2024 at 4:53 AM
    JackieDaytona
    JackieDaytona Well-Known Member
    2016 inferno sr5
    In progress
    MGMDesertTaco[QUOTED] likes this.
  4. May 18, 2024 at 5:56 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Doesn’t hurt to remove the drums, clean components and lube the adjusters. Always good to adjust the brake shoes occasionally.
  5. May 18, 2024 at 7:30 AM
    Goldielocks
    Goldielocks Well-Known Member
    You have several good answers to your 'when' question. Here's my tip 'how' I work: As you disassemble a component, lay the removed parts down keeping them in sequential order. Like a book, you read the words from left to right, top to bottom. Don't touch the parts again until you are ready to pick it up, clean or replace it and then reinstall it beginning with the LAST one you put down!
  6. May 18, 2024 at 8:45 AM
    Bmw2Taco
    Bmw2Taco [OP] Well-Known Member
    2018 Blue 4x4 TRD Sport Premium
    Ok, I will be sure to give the shoes a visual inspection soon. The majority of my miles are highway so I imagine they should have plenty of life left. Worth a peek though.
  7. May 28, 2024 at 8:02 AM
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
  8. May 30, 2024 at 4:35 PM
    babylon5
    David
    Tried a little test on the permatex brakes lubes I have. The purple extreme ceramic and the orange silicone extreme ceramic.
    I put a blob on some tinfoil in the over at 500F for an hour
    This is how they looked. The silicone (orange) looked like it did indeed melt.
    The purple just stayed as it was.
    permatex advertises that the orange is non melting??
    Now in actual use I haven't seen this behavior from orange. Maybe a sustained 500F was not realistic. Take the results as you wish..
    After doing a little more reading 500F was way to hot. The listed dry boiling point of DOT 3 brake fluid is only 401 F so i am guessing unless a caliper seizes none of us will ever see 500F and if you do what happens to your brake lube is the least of your problems....
    Now I have to get this out of the oven before the wife comes home :rofl:
    turkeyslayer66 likes this.
  9. May 30, 2024 at 9:52 PM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Team oil drop YouTube great basic maintenance instructions
