Rear brakes make noise under light pressure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Eximius2286, Sep 28, 2018.
  1. Sep 28, 2018 at 5:27 PM
    Eximius2286
    Eximius2286 [OP] Beauvais - Attleboro
    Josh
    Attleboro
    2016 Tacoma SR5 V6
    My rear brakes make a slight whining noise at low speed under light pressure. It doesnt do it under medium to heavy pressure or at speeds of 8+ mph. Does this mean they're ready to be replaced or am I just hearing a little bit of friction?
    I know most disc brakes will squeal when theyre ready to be swapped but do drums do the same?
    HondaGM likes this.
  2. Sep 29, 2018 at 1:13 AM
    Tacozrule
    Tacozrule Active Member
    Vancouver area, BC
    2017 Tacoma DCLB
    KO2s, canopy, light bar, exhaust, remote start
    May need to be cleaned and adjusted. If they are noisey, have them checked. Drum brakes do not have squeel tabs.
    HondaGM and Eximius2286[OP] like this.
  3. Sep 29, 2018 at 7:23 PM
    Quicksandbeast
    Quicksandbeast Member
    Southern California
    2017 Quicksand Tacoma TRD Off-Road 4x4
    I had the same problem....took it in to Toyota the other day....they did a clean and adjust on rear brakes...light squeal went away for the second time...I am convinced now it is brake dust from initial braking and I will do a clean and adjust every 5k versus 10k recommended.
  4. Jun 2, 2023 at 10:52 AM
    Wilso14
    Wilso14 Active Member
    Philly Burbs
    2014 trd sport 6spd
    I had this light squeal from the passenger side drum at low speed as well. After a good cleaning with CRC it has subsided.
    HondaGM likes this.
