Rear brakes sticking?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by XC4ME, Feb 13, 2009.
  1. Feb 13, 2009 at 4:57 PM
    XC4ME
    XC4ME [OP] Well-Known Member
    Litchfield Park, Arizona
    05 Tacoma DC TRD Sport
    I just got my '05 DC Sport a few weeks ago. A noticed that after I come to a stop when I release the brake pedal to go, I hear a thud from the back brakes. Like they are stuck and release when i go. I have plenty of shoe left. Is this normal for the drum brakes?
  2. Feb 13, 2009 at 5:07 PM
    ugotdubbz
    ugotdubbz Well-Known Member
    Chesterfield, Va
    06 DC PreRunner
    Rear spring TSB, OEM tube steps, in-channel wind deflector, OEM front seat covers,5100's up front set at 1.75"
    I got my 06 a couple months ago and it does the same thing. Between that and the tranny surge at a stop light I will go crazy.
    a400ryan likes this.
  3. Feb 13, 2009 at 5:42 PM
    nighthawk87
    nighthawk87 Well-Known Member
    You need a new drive shaft...mine did that and they replaced it. Problem gone.
    In the interim try unbolting the carrier bearing and tighting it back to spec. I think sometimes if it gets tightened while in the air it acts different when sitting on the ground. Its free and might fix the problem.
  4. Feb 13, 2009 at 7:45 PM
    frankrizzo1
    frankrizzo1 Well-Known Member
    San Diego
    05 Access Cab TRD Prerunner
    5100's at 1.75, Firestone Destination AT 265/75/16
    My 05 does the same thing, but I am not too worried about it.
  5. Feb 13, 2009 at 7:47 PM
    harshest
    harshest I am the Sofa King
    Michigan
    05 PreRunner SR5
    Fog Light On, Hidden Garage Door Opener, Scanguage II, Weathertech Liners, Cig lighter always on, Door buzzer removed from dash- Upcoming: 5100s for front and rear, set fronts to 2.5" and Toytec AALs.
    Lots of people have also suggested axle wrap, do you have the rear TSB done? My 05 does the same.
  6. Feb 13, 2009 at 9:42 PM
    XC4ME
    No I don't have the TSB done. What is axle wrap?
  7. Feb 14, 2009 at 4:31 AM
    harshest
    Michigan
    05 PreRunner SR5
    axle wrap : caused by torque of the rear wheels twisting the leaf springs into a sort of "S" shape. This is unwanted suspension movement that allows the pinion angle to change.The springs twist and untwist rapidly, causing the rear to hop under power. Spring-over axle leaf setups are more prone to axle wrap than spring-under configurations. Shock placement, such as one shock facing forward and one facing backwords, is done to reduce wrap. Axle wrap is also increased by lift blocks. Here is a simple diagram showing the leaf twisting under axle wrap.
    Some people have said that this has gone away with the upgraded leaf pack. I am going to do an rear add-a-leaf this summer. That has also bee known to take care of the problem. Like some one said before you might want to double check the drive line.
  8. Feb 14, 2009 at 4:57 AM
    AK27
    AK27 Well-Known Member
    i had thudding coming from my rear brakes, took it in and they said it was the brakes were loose. the head tech said that the tacomas all have this issue just on some its worse.... he said all they have to do was pack in some 'really heavy grease like stuff thats not grease' into the brake drum. ever since then i have had no issues with it
  9. Feb 14, 2009 at 7:58 PM
    frankrizzo1
    San Diego
    hmmmm..... interesting
    joba27n likes this.
  10. Feb 14, 2009 at 8:16 PM
    w8n4mud
    w8n4mud I'm back.
    Albert
    Chula Vista, CA
    2019 Tacoma Off Road DCSB
    Stock. Purchased 2/17/19. Cement!
    Mine does it too! I hate it and keep thinking the car behind me tapped my rear bumper. Im always looking like WTF? It does bother me a lot. Not much I can do about it now with 70k miles. If anyone actually knows any "facts" about it, please share. I had heard that the transmission was shifting into 1st as the truck would move forward (no punt intended Toyota). Now I read "drive shaft" and "axle wrap." Any TSB on this one? I do have a spacer in the front now and Toyota has already done the TSB in the rear for the leafs. Let us know. Curious minds want to know. Thanks.
  11. Feb 14, 2009 at 9:23 PM
    XC4ME
    Thanks for the explination harshest. I'll start with the drive line and go from there.
  12. Feb 15, 2009 at 9:44 AM
    nighthawk87
    Seriously...try loosening the carrier and re-torquing then let me know if that helps.
  13. Feb 28, 2011 at 8:40 AM
    ebulang
    ebulang Active Member
    Manny
    Cumming, GA
    SR5
    Any updates about this issue? I have been having this right now and waiting if I can get info from someone how to resolve it.:confused:
  14. Mar 19, 2012 at 9:25 PM
    memphis guy
    memphis guy Well-Known Member
    Nashville
    PreRunner TRD Off-Road
    Michelin LTX M/S II 265/75-16 Tires (+1 sidewall height)
    I've been having this problem for a few months now. When I come to a stop, there is a "bump," from the rear brakes, then when I release the brake pedal, there is a thud - it feels like the rear brakes don't release fully until a second or so after the front brakes.
    '07 PreRunner Access Cab V6, TRD Off-Road, 92,000 miles, original brakes all the way around.
  15. Sep 15, 2023 at 8:08 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    i know this thread is old but i'm having the same issue. anyone resolve this?
  16. Sep 15, 2023 at 8:45 AM
    Peter603Taco
    Peter603Taco Well-Known Member
    Peter
    New Hampshire
    2013 TRD Sport DCLB
    It's likely not actually the brakes. I resolved mine by greasing the slip yoke, there's lots of how to threads on it.
    joba27n likes this.
  17. Sep 15, 2023 at 8:46 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    Have you put the rear end up on jack stands, put the truck in neutral and manually rotate the rear tires by hand? Make sure you chalk/block the front wheels to prevent movement since the parking brake is on the rear wheels. The opposite rear wheel should rotate counter to your rotation because of the magic of the rear diff. It is possible that your rear parking brake adjuster gave up the ghost. On the inner face of the rear drum will be a rubber plug that you can counter rotate the adjuster then pull off the rear drum to check the rig. You may have broken a spring in your rear drum causing the shoes to shift. Just a word for the wise, backing up while braking will help to keep your rear adjuster properly tight.
    -J
  18. Sep 15, 2023 at 8:47 AM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    mine are dragging. both rear drums get much hotter than the front brakes. there is slight resistance in one spot on the driver's rear and no drag that i can tell on the passenger rear. What's unusual, is the passenger rear seems to get even hotter after driving for a while than the other side. feels like i'm towing a trailer when accelerating from a stop once they get hot. transmission gets hotter than normal too from all the drag. MPGs down as well.
  19. Sep 15, 2023 at 8:52 AM
    Peter603Taco
    Peter
    New Hampshire
    2013 TRD Sport DCLB
    oh well that sounds like a very different issue than the thud the OP for this old thread described. I'd start with looking at the shoes and making sure nothing is broken and everything is properly lubricated and moving freely. Check the adjustment of the shoes or maybe even e brake and go from there
  20. Sep 15, 2023 at 8:53 AM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    i got the thud too. i've tried lubricating everything but didn't really help at all. will try inspecting it again this weekend.
