Rear brakes
Discussion in '1st Gen. Tacomas (1995-2004)' started by VintageFast, Nov 10, 2015.
  1. Nov 10, 2015 at 3:54 PM
    VintageFast
    VintageFast [OP] Well-Known Member
    Jim
    DFW, Texas
    02 Prerunner 3.4
    How do we know if our rear brakes need to be adjusted?
  2. Nov 10, 2015 at 3:59 PM
    Clearwater Bill
    Billy
    Largo Florida
    always the opposite of what you guess. o_O
  3. Nov 10, 2015 at 5:38 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, LonePeak wedge camper, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    I always heard if you get about 12-18 clicks while pulling your e brake handle then your rear brakes are in adjustment. Using your e brake and braking in reverse automatically adjusts them periodically, but the tech manual article Rock Lobster posted is the best way to get them in adjustment to begin with.
  4. Nov 10, 2015 at 5:45 PM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    That lever usually prevents you from reducing the spread of the shoes and not the other way around. You can usually adjust outward with just a screwdriver. If you can easily spin the adjusting wheel, you are going in the right direction.
  5. Nov 10, 2015 at 6:45 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    This!!
    When I had my toyota buddy adjust my drums, i was only able to pull the e-brake out 3 clicks after the adjustment. after some time, maybe 6 or 7. before the adjustment it was like 14 or so.
    if you have more than 10 clicks, and get them adjusted, your brakes will engage much sooner. keep that in mind on your first drive!
  6. Nov 11, 2015 at 1:08 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    The only thing that keeps the rear brakes adjusted is using the emergency brake .
    Unlike American vehicles that adjust when applying brakes in reverse
    Which needs to be in good working order
    I seem to have no problems with drum brakes.
    Then when I change shoes every thing gets replaced .
