Rear Breaks replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacofish, Mar 29, 2016.
  1. Mar 29, 2016 at 5:40 PM
    tacofish
    tacofish [OP] Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    Any treads on replacing rear breaks
    Going to do mine soon, haven't messed with all those springs in a long time.
  2. Mar 29, 2016 at 5:43 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    Best piece of advice is to take pictures on each side before and after and try to do one side at a time. I would also try to take it apart as an assembly if at all possible. Get a new spring kit from the auto parts store they are cheap and it makes things 100 times easier
    PSU Taco85 likes this.
  3. Mar 29, 2016 at 6:06 PM
    tacofish
    N NJ
    14 ext cab 4x4
    Fireturk -
    Thanks for the suggestions
    Will do
    Let ya know how it goes
  4. Mar 29, 2016 at 7:27 PM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    Pretty much all drum brakes are a similar design so just watch a YouTube video for a how to drum brake replacement and that should give you a good starting point. And as mentioned, one side at a time and take pictures for reassembly.
  5. Mar 29, 2016 at 9:08 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    I just did mine....just remember to adjust your parking brake correctly when you are finished. Manual or auto?
  6. Mar 30, 2016 at 5:37 AM
    tacofish
    N NJ
    14 ext cab 4x4
    Auto
    This is my 3rd Taco
    Never had to do the backs before, they usually last forever.
    I'm at 150000 now
  7. Mar 30, 2016 at 8:08 AM
    esse10
    esse10 Well-Known Member
    Texas
    05prerunner SR5 DBLCAB
    I second that. I removed and inspected my rear brakes two weeks ago and they still had plenty of padding. I'm at 143k miles. I think I'll inspect them again at 200k miles.
  8. Mar 30, 2016 at 10:27 AM
    tacofish
    N NJ
    14 ext cab 4x4
    Just finished brakes
    Took about 2hrs total.
    I know a little slow but took both sides off and took my time.
    Definitely a bit different than others I have done.
    Prob had about another 10k to go.
    Thanks for all the help!
