Rear Bumper Adjustment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Silva1181, May 6, 2022.
  1. May 6, 2022 at 6:20 AM
    Silva1181
    Silva1181 [OP] Well-Known Member
    Marc
    Houston
    2013 Tacoma Double Cab, 2.7L, Silver Streak Mica
    Hello All, quick question and first time doing this. I've seen some video showing how to remove the rear bumper, but I am only looking to align the passenger side. I want to be sure I don't over do it with loosening too many bolts. My passenger side was slightly pushed in and up. I see the 3 bolts on the bracket which hold it to the frame. Are these the only ones I loosen to make the adjustment, or are there others?
    thanks,
  2. May 6, 2022 at 6:35 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Yes sir
    cryptolime likes this.
  3. May 6, 2022 at 7:56 AM
    Silva1181
    Marc
    Houston
    Thank You
  4. May 6, 2022 at 8:29 PM
    Homeline
    Homeline Well-Known Member
    2013 Access Cab 5-Lugger
    2" Leveling Kit, TRD skid plate, 16" Jeep wheels, Katzkin leather seats w/heaters, jump seat delete
    There are 2 bolts on each bracket that attach bracket to bumper. Loosening these will allow some tilt adjustment as well.
  5. May 7, 2022 at 12:05 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    The outer ends of the bumper easily bend and have a cheap support bracket that bolts in the back. You can simply hang on the lower edge and it will usually pull back down and out. Those brackets can be purchased separately if you care to. Rock ledges love to push those bumper ends up and break tail lights. Pulled mine down a time or two but only real solution is a new aftermarket stronger bumper if it bothers you.
  6. May 7, 2022 at 5:01 AM
    Silva1181
    Marc
    Houston
    Thanks muddog and Homeline
    I will try your suggestions as well because loosening the bolts on the bracket that’s attached to the frame didn’t do anything.
  7. May 7, 2022 at 10:18 AM
    did_you_say_tacos
    did_you_say_tacos Well-Known Member
    2010 White TRD Off-Road Crew
    Toytec Eibach/Bilstein 5100 3" Lift Stealth Custom Series SR8 Bronze 17x8.5 Cooper AT3 275/70/17 Bestop Softop Thule Rack
    Replaced my taillight last week because of this lol
