Rear Bumper and License Plate Light
Discussion in 'Pelfreybilt Off-Road' started by Scott B., Jul 28, 2017.
Thread Status:
Not open for further replies.
  1. Jul 28, 2017 at 10:05 AM
    Scott B.
    Scott B. [OP] Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    On my standard clearance rear bumper, I installed the license plate flip-up (down in this case) to allow me to use the receiver hitch. As most people do.
    I also installed the factory license plate lights in the bumper cutouts - as most people do.
    My question is, does anyone adjust the lights to properly illuminate the plate? On mine, the lights are focused behind the plate, so the plate is rather dark. I personally don't care, but don't want one of the boys or girls in blue to explain to the me that the plate is not illuminated and needs to be.
    What do people do?
    ChadsPride likes this.
  2. Jul 28, 2017 at 11:03 AM
    Socalduckslayer
    Socalduckslayer Pelfreybilt Off-Road
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    There is no adjustment on the license plate lights unfortunately. The focus should not change however, the location and angle is nearly identical to stock. I cant imagine having any issues with law enforcement with the illumination, if its a real concern in your area you may consider changing out the bulbs for a brighter LED version.
    Hopefully this helps, let me know if I can assist in any other way. Thanks so much for your business.
  3. Jul 28, 2017 at 11:53 AM
    Scott B.
    Scott
    Georgia
    The location and angle are nearly identical to stock - however, the plate is not on the bumper surface, rather about 1/2" proud of the surface, due to the flip-up. It seems like the light is aimed toward the bumper surface - I am sure Toyota did that to keep from having stray light.
    I did swap to LEDs, which are considerably brighter.
    I'm not worried about it, and have not had any problems with it. I guess I was just curious...
    BTW, I will be ordering a front bumper this fall. :kona:
  4. Jul 30, 2017 at 3:00 AM
    Dr. Jekyll
    Dr. Jekyll Well-Known Member
    Jimmy
    Honolulu, HI
    2015 Black DCSB Limited PreRunner
    I have the same issue and would be interested in seeing a solution, my plate is nearly black at night.
  5. May 22, 2018 at 5:33 AM
    TRDProBuddy
    TRDProBuddy Well-Known Member
    MD (Kent Island)
    2015 TRD Pro (Inferno)
    @Pelfreybilt, I just placed my order for my standard rear bumper and wondering if the issue with the license plate lights not pointing at the license plate due to the tag sitting off the bumper by 1/2" because of the flip up bracket has been addressed?
    Also, I would like to replace the hardware that mounts the tag lights and the trailer connector to your bumper with Stainless Steel hardware. Could you give the the sizes of fasteners used if possible?
    Thanks
  6. May 24, 2018 at 12:17 PM
    Pelfreybilt
    Pelfreybilt Pelfreybilt Off-Road, Inc.
    Pelfreybilt
    El Cajon, California
    2014 4Runner
    ~ Pelfreybilt aluminum 4runner front bumper and Rocksliders coated by Line-X San Diego ~ Baja Designs- LED Lighting Grill with LED lightbar & 40" roof rack lightbar ~ Rigid Industries rock lights ~ Front Runner Outfitters roof rack, fridge slide & bottle opener ~ CVT Rooftop Tent & Awning ~ Goose Gear storage drawers ~ Katzkin Leather seat covers ~ Switch-Pro control kit ~ Factor 55 Flatlink ~ WARN VR8000-S Winch ~ Fuel Offroad Trophy Wheels ~ Goodyear Kevlar Tires ~ ICON Vehicle Dynamics Stage 5 kit. Appx 2.5" lift ~ ARB lockers, skid plates & 50qt Fridge ~ JL Audio custom stereo system
    Thank You for the order. With the current configuration there is no issue illuminating the license plate light. Here is the parts list for the rear bumper, the license plate lights use the #8 hardware
    05-15 Tacoma Standard Rear Bumper:
    (10) M12 Flat Washers, Large Diameter/Fender, Zinc
    (6) ¼-20 x 1” Button Head Screws, Zinc
    (6) ¼-20 Nylock Nuts, Zinc
    (2) #8-32 x 1 Oval Head Phillips Screws, Zinc
    (2) #8 Nylock Nuts, Zinc
    (8) #10-24 Nylock Nuts, Zinc
    -Pelfreybilt
    www.pelfreybilt.com
  7. May 24, 2018 at 12:45 PM
    Scott B.
    Scott
    Georgia
    Speaking from my 2015 with Standard Rear Bumper and LEDs in the license plate lights, your statement is correct only if one does not use the license plate flip-up kit.
    However, with the flip-up, the light is aimed/focused behind the plate, leaving the plate somewhat dark.
    A solution I have thought of, but not implemented, is to build some wedges to raise the inboard end of the light fixtures 1/2", to move the light beam to the plate. I imagine some could be 3D printed rather inexpensively. I also looked for some aluminum wedges, but was not able to find anything suitable.
    At this point, this is not a high priority for me. Once I catch up on my project list, I may try to solve this.
Thread Status:
