Rear bumper bolt size - any tips as I swap out stock for an All Pro
Discussion in '1st Gen. Tacomas (1995-2004)' started by rmorit_DC_04, Apr 18, 2016.
  1. Apr 18, 2016 at 11:43 AM
    rmorit_DC_04
    rmorit_DC_04 [OP] Well-Known Member
    Bob
    2004 Double Cab - new to me in 2015
    ARE Tonneau Cover
    I was crawling under the truck this weekend, hitting the 4 bumper bolts that attach to the frame with PB Blaster.
    Seems like they are 19mm, but I noticed the "nuts" that are inside the access holes are rusted to the point that the socket isn't quite a perfect fit.
    Just wanted to validate if anyone had tips for attacking those bolts, did you hit the nut with the impact wrench since those are "inside" the frame access hole?
    I am going to drop the spare since it seems to be in the way. Any tips would be appreciated.
    Thanks - Bob
  2. Apr 18, 2016 at 11:51 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    It's been a long time, and forgive me if this is mis-information, but IIRC, those nuts are welded on. All you have to do is remove the bolts and reuse them with the new bumper.
  3. Apr 18, 2016 at 11:54 AM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    Those nuts are welded to the frame
    Digiratus likes this.
  4. Apr 18, 2016 at 5:39 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    X's 2^^^^^ those two front most bolts have the nut welded in place.
  5. Apr 18, 2016 at 8:15 PM
    rmorit_DC_04
    Bob
    ARE Tonneau Cover
    Thanks - I got it removed tonight - 2 bolts had welded nuts to the frame and the other two weren't - front most have welded in and I could see that there was anti-seize on them and the rear most are just a bolt and a nut.
    The welded in were a cinch, the nut/bolt were a pain but the rear bumper is off!
