Rear bumper bracket bolt thread/size?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Backinblack03, Jun 2, 2017.
  1. Jun 2, 2017 at 2:17 PM
    Backinblack03
    Backinblack03 [OP] Well-Known Member
    Brian
    VT
    2003 Xtra cab 4x4 2.7/5spd
    ABS sucks.
    Hoping to install a hitch this weekend. The bumper bracket bolts that pass through the frame have been there for 14 years, and will probably not come out willingly and may have to be destroyed. Does anyone know what the size and thread pitch are?
    Thanks!
  2. Jun 3, 2017 at 1:20 AM
    Stutely
    Stutely Well-Known Member
    Jonathan
    Central IL
    99 Xtra/3.4/5 speed/SR5/TRD/4x4 Burgundy "Ron"
    Just bought some actually:
    m12x1.25
    You're gonna need a torch to remove them. Just heat the bolt head for a bit and then crank on them. Extra leverage helps. I used a pipe clamp slid over my socket wrench.
    The one closest to the cab screws into a welded nut, but the one closest to the rear has its own nut. I think they're 17mm socket size.
  3. Jun 6, 2017 at 5:05 PM
    Backinblack03
    Brian
    VT
    ABS sucks.
    19mm actually, and thanks for the info! Got it all installed in under 2 hours. In the dark. In the rain...
    Stutely likes this.
  4. Jun 6, 2017 at 7:07 PM
    TooMuchToDo
    TooMuchToDo Well-Known Member
    2002 Gold Tacoma XtraCab with 192k
    ...we'll get there.
    Didn't realize there was one loose nut until I cranked for way too long. Reached in and finally felt it spinning. ... live and learn
