Rear Bumper Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by danbow, May 10, 2010.
  1. May 10, 2010 at 9:17 AM
    danbow
    danbow [OP] Well, known member
    Daniel
    Wichita Falls, TX
    09 DCSB TRD OR 4x4
    Scratches and Dents
    I just modded my factory chrome rear bumper by backing into a giant rock on a camping trip this weekend. (also tore up the 7 pin connector) no other damage, but I thought this might be a good time to make a change. I'm trying to find either an OEM black rear bumper or a reasonably priced, as in no more than an oem bumper.aftermarket rear bumper. Any photos, vendors and random comments appreciated.
  2. May 10, 2010 at 9:28 AM
    buck
    buck Don't sweat the petty - pet the sweaty
    Ontario, Canada
    08 DC V6 4x4 TRD Indigo Ink
    High-flow coconut smiley-face air freshener.
    If it's just the bumper cover that is bent or dented, the color matched OEM one from the dealer is in the $200 range, where as the chrome one is in the $400 range. The color matched one comes primed to paint. Body shop shouldn't be much more than $100 to paint it.
    There is bracing underneath the bumper as well. Check to make sure that's not jacked up too. The piece that gives the bumper tongue weight support is $2XX if it is bent.
  3. May 10, 2010 at 12:39 PM
    danbow
    Daniel
    Wichita Falls, TX
    09 DCSB TRD OR 4x4
    Scratches and Dents
    thanks, I looked under the rearend after it happened, the point of impact was really mostly on the 7 pin, apears none of the brackets were bent.. bad news is definately a dent in the chrome bumper(I've only called them bumper covers if they are plastic over a bumper reinforcement)
  4. May 10, 2010 at 2:04 PM
    buck
    Ontario, Canada
    The rear bumper face is still sort of over a reinforcement. The piece that the bumper mounted hitch would mount to is the reinforcement so to speak. There are also stiffeners in the corners of the bumper.
    Check out a micro-fiche if you have a chance and you'll see what I mean.
    I was rear-ended and the bodyshop quoted just the bumper face... well, the reinforcement was also bent which cost an additional $2XX bucks.
  5. May 10, 2010 at 2:25 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    Bummer dude. I wish I already had a tube bumper built for mine and I'd sell you my stock black one...
  6. May 10, 2010 at 3:32 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    get a base ATO bolt on...flush mount the 7pin in it and add the hitch if u need it...mmmmmm
  7. May 10, 2010 at 3:54 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    Drive to VA and buy my stock chrome one. I'll sell it for $300 and it's spotless.
  8. May 10, 2010 at 4:59 PM
    cntmdc
    cntmdc Well-Known Member
    Pablo
    Delray Beach,Fl
    09 PreRunner SR5 "Super White"
    Undercover Toneau cover, Billet Grill, bug deflector,Fog light Mod,Nerf bars,17" TRD Sport wheels, stainless mirror covers,LED Guage cluster "Blue",SS Front Skid Plate,Custom "SOCKMONKEY" SR5 Decals, OEM TRD SS exhaust tip,shorty antenna,Clarion DVD Head unit,Bilstein 5100's Front shocks,Toytec 2"AAL,Custom Racing Stripe hood,roof & tail gate
    My bumper got ruined by carrying pool acid in my bed with my undercover on.The jug tipped and spilled about 1/4 cup on the bed and some trickeled on the bumper killing my Chrome finish.When I called the dealer for a replacement they told me $465.00 plus tax for the chrome part only (no plastic foot step etc.). Whenasked about the painted ones (Sport) they told me that I needed the VIN # of a sport to find the stupid part#. I found the replacement bumper on Ebay for $282.00 pluse $30 shipping which was better than the dealer price and got it 3 days.The installation wasn't too bad however when I got rear ended last year the 7 Pin connection got cut off and they had to replace the whole hitch assembly as well as the bumper on mine and the body shop said that the hitch was around $1200.00 OEM.Maybe you could find the hitch aftermarket to fix the connector.Good Luck with it Bro.Here's the link for my bumper:http://cgi.ebay.com/ebaymotors/05-0...025QQitemZ380230510724QQrdZ1QQsspagenameZWDVW :cool:
    Once you get on his store you might find a Black one that fits your truck.
  9. May 10, 2010 at 5:32 PM
    High-Gear
    High-Gear Zombie Killer
    Newton, KS
    09 TRD Off Road
    TRD Supercharger, TRD Cat Back Exhaust, DR / Icon 2.5 Coilovers, Camburg UCA, TSB with AAL, Walker Evans 2.0 reservoir rear shocks, ARB Bull Bar, Smittybilt 10K Comp Winch, ARE Camper Shell, Con-Ferr Safari Rack, 4 KC Highlights on rack, 2 KC Rallye 800 on Bumper Armortech Off Road plate rear bumper. Firestone Airbags in rear, with Firestone compressor.
    I did the same mod, but I used my neighbor's truck! The stock tin foil bumper folded up and pushed in the bedside and tail lamp, causing $3800 worth of damage.
    A factory rear bumper was $465. I purchased one of Armortech Offroad's bumpers for $500 to my door if I remember correctly. This bumper is way more stout and has recovery points built in.
    http://www.tacomaworld.com/forum/armor-tech-offroad/42419-armor-tech-offroad-product-line.html
    This 5th bumper down is mine. I had him put the trailer connector in the bumper so it did not get damaged, and had high lift notches put in.
  10. May 10, 2010 at 6:13 PM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Don't you have the back up camera on your 09'?
  11. May 11, 2010 at 11:50 AM
    TryingTacoma
    TryingTacoma Member
    Canada
    2010 AccessCab 4X2 2.7L 4cyl Auto
    Engine Hour-Meter, Fumoto Oil Change Valve, Rear RideRite Helper Air Springs and Left/Right Pressure Guages.
    I was "mildly" rear ended at a traffic light and think I only need the chrome part of the bumper (about $473 plus taxes). I'll take your hint and look again for other damage to supports.
    I have two questions.
    1. Is it easy to remove and re-use all of the plastic bits, like the step area, that are attached to the chrome part of the bumper?
    2. Is there a colour matched bumper to replace the chrome one? This damaged one is now rusting beyond the original impact area just due to the stresses placed on the chrome plating at the time of the impact. Its pretty thin plating.
    Thanks
  12. May 11, 2010 at 5:27 PM
    buck
    Ontario, Canada
    All of the plastic comes of relatively easy. The only bugger is the end-caps on the top corners of the bumpers. You have to spin off a couple of nuts to remove, but the stud is radially supported by a channel in the plastic cap. Spray it good with PB or WD40 to help loosen it up.
    You can get the colour mathed bumper from the dealer. It's almost 1/2 the price as the chrome bumper. You just have to get it sprayed, but you'll still be cheaper in the end than if you were to purchace the chrome one.
  13. May 12, 2010 at 6:38 AM
    TryingTacoma
    TryingTacoma Member
    Canada
    Reply to Buck,
    Thanks for the info on changing and colour-matching the rear bumper. I can make a much better decision now.
  14. May 13, 2010 at 8:53 AM
    danbow
    Daniel
    Wichita Falls, TX
    09 DCSB TRD OR 4x4
    Scratches and Dents
    HAHA.... yes, i do have a backup camera.. that's what everyone I know has said to me when they see the dmg on the rear bumper :anonymous:
    The trick is to actually use it when you are backing up
  15. May 13, 2010 at 9:25 AM
    Bretsuaz48
    Bretsuaz48 Well-Known Member
    Bret
    Surprise, Arizona
    2016 Sport
    There was a chrome one on Craigslist here in Phoenix recently for cheap. I saw it on there and called a friend about it because she had jack knifed a trailer and messed up her bumper, but she had already replaced it. I don't see it now. I would have picked it up and shipped it to you.
    I called the Toyota yard up in Sacramento. They want $650.00 for the whole bumper!!!!!!! That is just crazy IMO.
    I have been thinking about replacing mine with the sport bumper and painting it white. I will let you know if you are iterested we can work something out to get it to you.
  16. May 14, 2010 at 7:45 AM
    TryingTacoma
    TryingTacoma Member
    Canada
    Reply to Bretsuaz48,
    Thanks for the offer, but I'm not in a rush to change my bumper. Just looking for the alternatives. Now I know they can be painted I might even get the dents removed and then paint it as is.
  17. Jul 8, 2010 at 11:50 AM
    danbow
    Daniel
    Wichita Falls, TX
    09 DCSB TRD OR 4x4
    Scratches and Dents
    update on the rear bumper situation
    -getting the shop to replace the chrome with a color match BSP bumper
    -also getting a LOT of redneck pinstripes buffed out
    -and a dent on the front pass side door from a serious door ding
    can't wait to get me renewed tacoma back!!
  18. Jul 8, 2010 at 12:23 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
