Rear Bumper not even - Anybody else have this happen?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mattRADICAL, Oct 18, 2017.
  1. Oct 18, 2017 at 11:45 AM
    mattRADICAL
    mattRADICAL [OP] Active Member
    Virginia
    2017 DCSB TRD Sport
    Hey guys,
    I have a 2017 Tacoma DCSB and was wondering if anybody else has seen this or had it happen to them.
    Shortly after buying my truck I noticed the rear bumper wasn't aligned the same on both sides. I went to the dealership and they had to put it on the lift and take it completely off and reinstall it to get aligned right. They also kept asking if I got hit or if I hit something which I hadn't.:frusty:
    I just rolled over 5000 miles and noticed it's not aligned again and the same side is sticking out. I looked under it to see if there was a anything loose or a way to fix it myself but didn't see anything. Everything I could find was tightened and the bumper itself was solid.
    Has anybody else had this happen? If so did you find a way to fix it?
    It also is way more noticable in person. The photo's make me look really OCD :rofl:
    Left Side
    Right side
    Thanks!
  2. Oct 18, 2017 at 1:08 PM
    etozz221
    etozz221 Active Member
    San Diego, CA
    2017 Tacoma TRD Off-road 4x4 DCSB
    Maybe take it off and put it back on
  3. Oct 18, 2017 at 1:09 PM
    Simpleton
    Simpleton Well-Known Member
    Orange County
    2017 DCSBOR
    None as of yet
    there are tons of threads on this already. check your bed too. It may be out of alignment
    Catfish21 and mattRADICAL[OP] like this.
  4. Oct 18, 2017 at 1:10 PM
    w:ll:s
    w:ll:s Well-Known Member
    Nashville, TN
    2001 Tacoma v6 4x4 SR5 - Imperial Jade
    maybe someone backed into you in a parking lot...
  5. Oct 18, 2017 at 1:12 PM
    newbson9696
    newbson9696 Well-Known Member
    Chad
    Southern California
    2021 SUPER WHITE DCSB TRD OR
    Could certainly be an alignment issue with the bed, just have it checked out! Happened to my pops on his truck and that was the issue
    mattRADICAL[OP] likes this.
  6. Oct 18, 2017 at 1:17 PM
    mattRADICAL
    Virginia
    2017 DCSB TRD Sport
    Looks like that's exactly what is the issue. Thank you!!
    Simpleton[QUOTED] likes this.
  7. Oct 18, 2017 at 7:57 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    90% of tacos are just like yours. It a piss poor deign combined with an equally piss poor assembly technique. So far it’s my only real complaint about my Taco. They could have every taco roll off the assembly line perfectly lined up but they cut corners to speed production and they don’t adjust them even though they could.
  8. Oct 18, 2017 at 8:12 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    your bed might be out of alignment. Maybe the dealer can help.
  9. Oct 18, 2017 at 8:38 PM
    rsimi72
    rsimi72 Well-Known Member
    PNW
    2020 Tacoma SR5 Access Cab
    There is a little bit of play once you get the black step pad off. I think I loosened 4 bolts once under there. You may need to adjust each side a tad to get the two gaps to even out. Hardest part for me was popping the license plate lights out. And pulling the step pad requires a bit of force. Good luck. Pretty simple job with lots of info and step by step instructions available here.
  10. Oct 18, 2017 at 8:43 PM
    ICU1
    ICU1 Well-Known Member
    Same thing for me QS. Dealer refused to fix stating it was in an accident. BS.
  11. Oct 18, 2017 at 8:46 PM
    rsimi72
    PNW
    :facepalm::frusty:
  12. Oct 18, 2017 at 8:47 PM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    Same problem on a new PRO. One day I will fix it.
  13. Oct 18, 2017 at 9:20 PM
    Catfish21
    Catfish21 Well-Known Member
    Stockton, Ca.
    Trd off road 4th Gen
    same here i asked kendall toyota of fairbanks to fix it, they said thats not their problem. you know what. fuck it.
  14. Oct 19, 2017 at 7:47 AM
    D.W.B
    D.W.B Well-Known Member
    Dennis
    Mar Vista, CA
    TRD OFF-ROAD
