Rear bumper replacement.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gasturbine, Jan 24, 2017.
  1. Jan 24, 2017 at 11:43 AM
    Silverspool
    Silverspool Come at me Bro!
    Frank
    DFW
    18T4RORP 17GT350
    Anyone seen my wallet?
  2. Jan 24, 2017 at 11:43 AM
    Gasturbine
    Gasturbine [OP] Well-Known Member
    Central Ohio
    2011 Regular Cab 2.7l 5-speed 4WD
    32" BFG KO tires on MT rims, Front lifted 2", N-Fab 12,000lb front pull point w/10,000lb red clevis, mud flap delete, tail pipe delete, 20" LED light bar, 2 Hella 500s, N-Fab light bar mount, tinted windows.
    Truck is brown, but the bumper is black.
    Is it clean?Gotta pic? I would trek to the north coast for the right deal.
  3. Jan 24, 2017 at 11:43 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    When I got rear-ended I got the other driver's insurance company to cut me a check for the damage ($650). I took that and bought the All-pro bumper seen here: After sealing the bumper myself with primer and bed-liner, and then having a body shop install it, I was only out about $50. Not too bad.
  4. Jan 24, 2017 at 11:45 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    If you want to drive down to northern Virginia I have a barely dented bumper off off a 2014 Tacoma. I've got it on Craigslist for $350.
  5. Jan 24, 2017 at 11:47 AM
    Gasturbine
    Central Ohio
    Thanks, but Ive already found a OE aftermarket skin for $120.
    EDDO likes this.
  6. Jan 24, 2017 at 11:49 AM
    Gasturbine
    Central Ohio
    Guys, I do not want to spend $500-$1000 for a bumper on this truck. I dont off road, and its my 3rd vehicle. I appreciate all the advice, but I want to fix this as cheaply as possible.
  7. Jan 24, 2017 at 11:58 AM
    uhplifted
    uhplifted The Hopfather
    Brian
    Huntington Beach, CA
    16 DCLB OR
    Sounds like you should try and find someone's OEM takeoff then. Steel will cost 1000+ wish I could help recommend a place to look other than here and Craigslist. Good luck.
  8. Jan 24, 2017 at 12:00 PM
    uhplifted
    Brian
    16 DCLB OR
    I'm not saying you're wrong, but I haven't seen any that are less than maybe 900. But then again I wasn't looking to get a cheap (read: money wise, not quality) bumper as all the ones I looked at had all the bells and whistles.
  9. Jan 24, 2017 at 12:14 PM
    Tretiak30
    Tretiak30 Well-Known Member
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    $200 and it's yours. It was on the truck and I went with a aftermarket right before winter a few years back so it's clean. The hitch has rust since it's original but everything's still good
  10. Jan 24, 2017 at 12:24 PM
    Gasturbine
    Central Ohio
    Okay, thanks for the offer and the pic, but Ill pass. I found new OE after market for $120...looks like thats my best route. Thanks again.
    Tretiak30[QUOTED] likes this.
  11. Jan 24, 2017 at 12:42 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Op.. Remember, you might have to replace some bumper brackets and such. The stock ones are soft and could be bent
  12. Jan 24, 2017 at 12:52 PM
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    $150? I just want it gone!! Haha
  13. Jan 24, 2017 at 1:09 PM
    Gasturbine
    Central Ohio
    Tretiak30[QUOTED] and uhplifted like this.
  14. Jan 24, 2017 at 1:15 PM
    Gasturbine
    Central Ohio
    got it. Thanks for the heads up.
  15. Jan 25, 2017 at 8:08 AM
    #35
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    Is that black (202)? Or mgm? Or base model black? I'm interested
  16. Jan 25, 2017 at 9:03 AM
    #36
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    Black sand mica or something close to that. Can't remember the exact name.
  17. Jan 25, 2017 at 9:16 AM
    #37
    spiralout462
    Eastern Shore VA
    2015 4x4 dclb
    Black sand pearl I guess. I need black 202.
  18. Jan 25, 2017 at 9:21 AM
    #38
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    Mine is pre-2012. Not sure if they changed it but it came off a black 2010 SR5.
    I will look at the door tag or manual later today and check the code.
  19. Jan 25, 2017 at 9:23 AM
    #39
    16Tacos
    16Tacos Well-Known Member
    Zach
    Boston
    08 Access Cab 4x4 V6 SR5
    OME Nitrochargers w/886s & Dakars, ARB Deluxe Bull Bar w/Warn winch, RCI sliders with kick out, IFS & Mid skids, BFF Hi-clearance rear bumper, Brushed Copper 17" SCS Ray10s w/285-70 KO2s, Black OEM 16" steelies w/255-85 KM2s, Leer contractor cap w/Smittybilt overlander xl RTT, Off-Grid Engineering dual battery kit and bed power panel, Blue sea aux fuse block, Wyntner 60L fridge freezer, ARB dual compressor, Pioneer 720BT head unit, CB radio, @Matt_Gecko bed and engine bay lights, @TacomaTruckParts Dirt bike tie down bar, color matched OEM grill, A-Pillar phone mount mod, @Docloco rear seat molle panel
    I bought just the rear bumper "skin" and had it Line-x'd (comes in black primer). Was less than $200 before line-x but can't remember where I bought it, maybe Toyota Parts Barn.
  20. Jan 25, 2017 at 9:23 AM
    #40
    spiralout462
    Eastern Shore VA
    2015 4x4 dclb
    I don't know when it changed either. My 2012 is plain black. Thanks for looking!
