Rear Bumper ??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by george3, Sep 19, 2021.
  1. Sep 19, 2021 at 6:46 PM
    george3
    george3 [OP] Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    My Rear Bumper is rusted out - My question - is the OEM bumper worth the extra money ? After market is so much cheaper - the OEM on my truck wasn't much quality to begin with - any experience, advise or links appreciated. Thanks.
  2. Sep 19, 2021 at 7:19 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Some come with the plastic pads installed and the outer corner braces while others are stripped basic bumper shell. Look at thickness too.
    Here is one example I was looking at:
    Amazon.com: Titanium Plus Autoparts, 2005-2013 Fits For Toyota Tacoma Rear Step Bumper Assy BLACK : Automotive
    Wanted to put a heavy welded steel higher clearance one until I saw all over $1000. but get what you pay for.
  3. Sep 19, 2021 at 7:31 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    I wouldn’t replace OEM bumper with OEM, unless it’s free from someone upgrading to steel/plate.
  4. Sep 20, 2021 at 8:19 AM
    SixtyDashOne
    SixtyDashOne Well-Known Member
    Collegeville, PA
    2021 ArmyGreen TRD Sport, 2007 Regular Cab 4x4
    you can get an oem replica for like $240 with the pads, and it will hold up just fine; if pricepoint is your concern
  5. Sep 20, 2021 at 8:54 AM
    george3
    New Jersey
    Thanks Guys for all your replies and information. Appreciate it.
