Rear bumpers w/intergrade tow hitch???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Charger92, Jun 12, 2017.
  1. Jun 12, 2017 at 7:42 PM
    Charger92
    Charger92 [OP] Built for pure function!
    British Columbia Canada
    2007 Tacoma double cab long box
    Who makes a rear bumper with intergrade hitch that is as strong or stronger than a factory hitch. Also, would adding a tire carrier and fuel can to the bumper reduce the tongue weight capability.
  2. Jun 12, 2017 at 7:52 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    lots of the places have integrated hitch, the issue is i dont think a single one of them is actually rated. so without actual ratings, you wont know if its stronger then the factory hitch. I do think the factory hitch is one of the stronger ones out there.
  3. Jun 13, 2017 at 10:01 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
