Rear cargo lights
Discussion in 'Lighting' started by matthew5olson, Jul 29, 2009.
  1. Jul 29, 2009 at 10:05 PM
    matthew5olson
    matthew5olson [OP] Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    I know Nissan has had rear cargo lights for a while. Not sure if they are on the 2nd gen taco. I have a 1st gen and wanted to put some on the truck. I wanted to put 2rectangle ones on either side of the brake light above the rear window. I have never done anything with lights.
    Any advice on what lights to get. I would like really bright ones as I would like to use them for hooking up my trailer in the dark, getting stuff out of the bed in the dark, etc. I thought I would just wire it to a switch in the cab somewhere.
    Where should I get the power for the lights from? Thanks for any help.
  2. Jul 29, 2009 at 10:10 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    i got my lights at walmart, its a kit comes with 2 lights, wiring harness, and a switch bulbs are h3 nice and bright.
