Rear clunk but not in neutral?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Logger, Nov 1, 2014.
  1. Nov 1, 2014 at 5:36 PM
    Logger
    Logger [OP] out for a rip are ya bud?
    Sam
    '13 TRD OR Double Cab
    Ok, Ok, I know I've beaten this axle wrap issue to death. I have not yet purchased replacement springs either, so go easy on me!
    Just wondering why my truck doesn't clunk, shimmy, shift around when I come to a stop in NEUTRAL. All other instances in DRIVE when I slow to a stop I get the notorious clunk. Curious if any others have experienced this?
    Is it because the drivetrain is "unloaded" or what???
  2. Nov 1, 2014 at 5:41 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    No tq on the driveline
  3. Nov 1, 2014 at 8:11 PM
    Logger
    Sam
    Got it. That makes sense, I've been in leaf spring denial. I'm just hoping that when I replace them it solves the issue... thanks.
  4. Nov 1, 2014 at 8:12 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    whatcha gunna replace with?
  5. Nov 2, 2014 at 12:32 AM
    03tacopat
    03tacopat New Member
    Pat
    Calgary, AB
    2003 Tacoma ext-cab SR5 2.7ltre
    6" Fabtech lift, warn winch, All Pro Baja front bumper, Oldman Emu rear Dakar leafs, Rear Bilstein 5150, Rear E-locker, ARB compressor, 33" TrXus road, 35" trail
    Had a bit of the same, ended up being pinion flange nut was loose on rear carrier, rear U joint and probably didn't help that the leaf shackle bushings and frame leaf hanger bushings were shot, 1.5" deflection side to side when u bolts removed, put new OME Dakar 2.5" leafs with their poly urethane bushings, 2.5" shackle hanger new bushings, 3" block (total 7" rear lift) all new bolts, u bolt flip kit and lots of new grease, its like brand new just a bit firmer and NO clunks or bangs anymore.
  6. Nov 5, 2014 at 5:11 PM
    Logger
    Sam
    Haven't quite decided yet...
    I was thinking of going with 5100's up front set at 2" and possibly stock replacement leaf packs and a AAL from General Springs and new rear shocks. Or, just getting the OME pack. I just don't want it sitting up too high in the rear.
    As it sits, my rear springs are junk and my shocks have 123k on them. I'm on a budget like everyone else so when it comes time to do it, I want to make the best decision.
