Rear cross traffic
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2023tacomer, Jul 3, 2023.
  1. Jul 3, 2023 at 4:18 PM
    2023tacomer
    2023tacomer [OP] Well-Known Member
    Anyone here add in rear cross traffic monitoring? How much and how hard. Would be a 2023 trd off road.
  2. Jul 3, 2023 at 4:18 PM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    ..why
  3. Jul 3, 2023 at 4:19 PM
    2023tacomer
    Because it doesn't have the option?
  4. Jul 3, 2023 at 4:20 PM
    LeakyAC
    I meant like why would you go out of your way to have that?
  5. Jul 3, 2023 at 4:20 PM
    Bishop84
    Bishop84 Well-Known Member
    It's not an add in, and any chance of doing so would cost probably well over 1500$ if not more.
    It's not like fog lights or seat heaters, its integrated into mirrors, cluster, modules, sonars etc.
    It's a nice feature but basically a no go for add on.
    shakerhood and Chew like this.
  6. Jul 3, 2023 at 5:31 PM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Rear cross traffic uses the BSM sonar. I’ve seen the question asked if it could be retrofit but haven’t seen anyone make a post about completing it. The wiring may already be present like the bed lights on 2020+
  7. Jul 3, 2023 at 6:06 PM
    betrayus
    betrayus Milk steak connoisseur
    Denver, CO
    2021 SR5 DCSB 4x4 AT (MGM)
    Stock
    Yeah but you can't have BSM w/o RCA, its all one package from factory. So good luck adding BSM + RCA aftermarket. It ain't gonna happen.
  8. Jul 3, 2023 at 6:30 PM
    musicisevil
    Alaska
    2019 TRD Sport
    Yea idk. I do know each of the bsm sonar modules is ridiculously expensive, so even if it where as simple as plugging sensors into existing harnesses and adding a switch, it’d cost an arm and a leg
  9. Jul 4, 2023 at 6:19 AM
    twtaco$
    twtaco$ Well-Known Member
    I did an aftermarket one 9 months ago still works perfect!! Cost me like $500
    Brandmotion Radar Blind Spot System with Cross Traffic Detection RDBS-1500
    Beerpayzdabillz and musicisevil like this.
  10. Jul 4, 2023 at 7:43 AM
    musicisevil
    Alaska
    2019 TRD Sport
    Very cool! I’d be interested to read about this install. Did you write it up anywhere by chance?
  11. Jul 4, 2023 at 9:32 AM
    twtaco$
    mic_sierra and musicisevil like this.
  12. Oct 24, 2023 at 2:38 PM
    Bill400
    Bill400 Well-Known Member
    Bill
    2023/7170 (SR5, V6, DBL Cab, 4X2) Red, Advanced Tech Pkg
    OEM BSM/CTA retrofit complete
    Oh Ye of little faith ... Not for the faint of heart and requires learning new skills. 3rd Gen BSM retrofit is possible.
    Some wiring may exist, depending on your model and options. Buying all new parts is cost prohibitive. And if you want to make it look OEM, learning to crimp very small connector terminals is a must.
    Stay tuned!
  13. Oct 26, 2023 at 9:46 AM
    betrayus
    Denver, CO
    Stock
    Good luck!
  14. Oct 26, 2023 at 3:07 PM
    Bill400
    Bill
    Thank you.
    I plan to document/share my experience doing the OEM BSM/CT retrofit.
    Lots of time invested studying wiring diagrams and learning that most Toyota connectors are Sumitomo.
    Also, it took more time to locate the correct crimp terminals to fit the connectors.
    Since I want OEM quality, had to learn how to crimp tiny 0.64 series terminals accurately to fit the connector housings.
    If "taps" and "compression connectors" are used vs OEM connectors and/or generic LEDs vs BSM mirrors, the cost and complexity of the retrofit can be reduced substantially.
    More on that later ...
    PS:
    At $600, the OEM BSM/CT option is reasonable.
    I was offered my spec truck (incl. both sonar-park assist. and BSM/CT) for $10K over SRP in Greer SC.
    Decided to settle for my spec, minus BSM/CT for much, much less and do it myself.
    stftaco likes this.
  15. Oct 26, 2023 at 4:06 PM
    twtaco$
    My brandmotion still works like a champ!! Rear cross traffic is awesome.
    Last post about it though.
    vivid02 likes this.
  16. Oct 28, 2023 at 2:25 AM
    Bill400
    Bill
    Thanks for the Brandmotion info. A good alternative to OEM.
  17. Oct 28, 2023 at 2:30 AM
    Bill400
    Bill
    $600 option on a new SR5 ...if you can get it.
  18. Jan 5, 2024 at 11:18 PM
    Bill400
    Bill
    Toycoma2021, vivid02 and musicisevil like this.
  19. Jan 7, 2024 at 1:59 PM
    twtaco$
    Awesome man. I do really like my aftermarket unit though I prefer the lights on the inside now not in the mirrors easier to see, and the brandmotion is almost $700 now I paid $500. But great job. :thumbsup: I’d definitely do whatever is the cheapest but the brandmotion was only if I remember correctly 2 turn signal wires, 2 wires go to obd, 1 ground, 1 12 volt it was pretty simple.
    Great to have another solution for this. :)
  20. Jan 7, 2024 at 5:55 PM
    Bill400
    Bill
    Thanks, it was an interesting challenge.
    Possible to do with all salvage parts, except custom wiring.
    A patient picker can do it quite cost effectively.
    I'll provide additional details, the pin-out that I used, in case anyone would like to replicate.
