Rear Cupholder Removal in AC
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rickcrna, Jan 10, 2015.
  1. Jan 10, 2015 at 10:07 PM
    rickcrna
    rickcrna [OP] Well-Known Member
    Rick
    Central Oregon
    '13 AC SR5 4WD I4 Auto MGM
    No luck with a search on this topic. Does anyone know if the rear cupholders located at the rear of the center console can be removed easily in an access cab?
    My big dog tells me it's annoying to have those cupholders jutting out into his riding space.
    Thanks in advance.
  2. Jan 11, 2015 at 5:44 AM
    3rail
    3rail Well-Known Member
    Donald
    Amish Country
    17 Tacoma Sport AC (Inferno Orange)
    TRD wheels and Nitto tires, TRD Pro grille, exhaust, CAI, skid PL & shift knob. OEM Audio Plus 450Q sound system upgrade.
    Do not know if they are the same but my 2015 AC is easy to take out. Pull out the little rubber mats in the cub nippy things, remove the 4 screws, it lifts right out. There will be a metal bracket attached to the floor but that can also come out easily with the removal of two bolts.....possibly 12mm.
    Hope that helps, you did say cup holder, mine are small storage cubbies but the concept should be the same.
    Donald
  3. Jan 11, 2015 at 9:06 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    Believe it's integral to the console.
  4. Jan 11, 2015 at 9:38 AM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    That entire rear console between the jumpseats totally removes. It's just two bolts if I remember. When I removed mine for my dog I installed thin black automotive carpet to cover the holes in the rug that will be exposed.
    Like the other guy said above, pull up the little rubber mats and you'll see the 10mm bolts.
  5. Jan 11, 2015 at 9:59 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    He's asking about the cupholders in the back of the center console, not the little cubby on the floor, which is what you guys are telling him about.
  6. Jan 11, 2015 at 10:03 AM
    B737
    Kevin
    Jersey Shore
    stock
    That's all part of the main center console. It's one big piece of plastic
  7. Jan 11, 2015 at 11:31 AM
    rickcrna
    Rick
    Central Oregon
    I was afraid that it might be integral to the center console. Thanks anyway for all your input. In my OP I was NOT referring to the cubby between the two jump seats but thanks anyway.
    Will have to splain the situation to the big dog now. :)
  8. Jan 11, 2015 at 12:09 PM
    TSJESME
    TSJESME Well-Known Member
    James
    Maui
    14 TRD SPORT A/C 4X4 M/T
    Have you checked out the dog platform thread?
  9. Jan 11, 2015 at 12:45 PM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    Wash your dog in hot water?
