Rear Dif leaking oil now!!!!
Discussion in 'Toyota Trucks & SUVs' started by 1999tacotrd, Oct 6, 2009.
  1. Oct 6, 2009 at 9:26 PM
    1999tacotrd
    1999tacotrd [OP] 1999 Taco TRD xtracab 3.4 V6 4x4
    We went mudding today in my 88 yota nothing extereme and on the way back stoped to get gas and noticed oil comeing out the top op the rear diff and running down the side and dripping on the ground! I though these trucks where built tuff but any way it would had been a simple fix but i noticed on this toyota that its ass backwards compared to other trucks which u can simply take off the dif dust cover and replace the seal well here it seems i have to take it off from the front side THE FRONT SIDE!!!! :eek: where the drive shaft hooks to the dif so how the hell do u do this? i know i tried to remove the shaft that hooks to the driveline on my 97 jimmy last winter when the rear end went out and it would not budge! i sure hope to god it comes out on the toyotas if not then i dont see any way of fixing this! What where they thinking when they made it like this? any way you guys have any ideas?
  2. Oct 7, 2009 at 5:13 AM
    98tacoma27
    Ben
    Not Beech Creek
    The FRONT SIDE is called the third member. In order to remove it you need to pull the axles out first.
    I would like to see some pics of this leak (if possible) as I am not certain as to what seal you are referring to.
  3. Oct 7, 2009 at 6:48 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    That's a Toyota thing.... (3rd member)
    Do some research....look for the torque specs on the 3rd member bolts and check to make sure they're tight.
  4. Oct 7, 2009 at 10:31 AM
    1999tacotrd
    Heres some pics of where its leaking! it starts where the arrow is and works it way down to the bottom
  5. Oct 7, 2009 at 10:32 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Clean your diff up, and torque the nuts to 50 lb-ft.
  6. Oct 7, 2009 at 10:35 AM
    98tacoma27
    Ben
    Not Beech Creek
