Rear Diff Breather Mod
Discussion in '3rd Gen. Tacomas (2016-2023)' started by eldedo, Jan 10, 2016.
  1. Oct 20, 2016 at 3:17 PM
    #41
    Jukeboxx13
    Jukeboxx13 Well-Known Member
    California
    2017 TRD OR DCSB 4x4
    Does anyone have a link to a how to thred like the AC mod?
    Thanks
  2. Oct 20, 2016 at 3:38 PM
    #42
    Bombagee
    Bombagee Member
    Marc
    2016 TRD-OR AC 6MT
    CygnusX191 likes this.
  3. Oct 20, 2016 at 5:00 PM
    #43
    Jukeboxx13
    California
    No I meant a how to diff brether mod similar to the AC mod thread.
  4. Oct 20, 2016 at 6:05 PM
    #44
    monsterkx2fiddy
    monsterkx2fiddy Well-Known Member
    Birthplace of Davy Crockett
    M61guru likes this.
  5. Oct 20, 2016 at 6:39 PM
    #45
    crymes
    crymes Well-Known Member
    Cameron
    CT
    2017 TRD OR DCSB QS
    im a noob and i may be absolutely wrong about the physics of this...but does installing this mod with the long hosing increase the resistance and ability of the breather to work as well as without it when just driving under normal circumstance? or does it not matter because it creates a strong enough vacuum? I understand the application of this for underwater purposes...but i just want to be sure it's not stressful for the diff to have this on in the long run.
  6. Oct 20, 2016 at 7:34 PM
    #46
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    The volume of the tube is inconsequential in and of itself if you used a one way.
    It matters even less because you are supposed to use a two way.
  7. Oct 20, 2016 at 7:43 PM
    #47
    crymes
    Cameron
    CT
    2017 TRD OR DCSB QS
    gotcha...was just randomly speculating
  8. Oct 20, 2016 at 8:51 PM
    #48
    Jukeboxx13
    California
  9. Jun 5, 2017 at 1:46 PM
    #49
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    bumping
    has anyone confirmed its a two way valve breather or just a vent?
    One of the reasons you'll get water in your diff with the normal vent is its a one way valve and when the diff cools rapidly in water crossings it turns into a vacuum and sucks water in from around the gaskets etc.
    The breather just lets it breathe. So are the other ones on the trans etc just a vent or an actual breather?
  10. Mar 16, 2018 at 9:35 AM
    #50
    FlyFisherCJ
    FlyFisherCJ Well-Known Member
    Cameron
    Twin Falls ID
    2017 TRD OR DCLB
    And has anyone mounted the breather behind a tail light? I think I remember seeing a picture a while back of someone doing that but i cannot find it...
  11. Mar 16, 2018 at 10:35 AM
    #51
    LoMa
    LoMa Well-Known Member
    2016 Tacoma TRD Sport AT MGM
    Yes.
  12. Mar 16, 2018 at 10:43 AM
    #52
    Farcedude
    Farcedude Well-Known Member
    Greg
    Westminster, CO
    ‘23 MGM DCSB OR
  13. Mar 16, 2018 at 11:44 AM
    #53
    Bagow
    Bagow Well-Known Member
    Arizona
    2016 DCSB OR 4x4
    With the 2 way breather aren't you at risk of letting dust enter the diff? Should there be a filter on the breather to prevent this?
  14. Mar 16, 2018 at 12:56 PM
    #54
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Havent you tried putting it in your mouth and sucking/blowing it?
    (Ok, Ok, I mean it seriously)! :crapstorm:
    Air goes both ways when you do it and the little cap helps keep stuff out.
    tonered likes this.
  15. Mar 16, 2018 at 1:00 PM
    #55
    OnHartung'sRoad
    I just mounted mine above the cubby box between the gas filler area and the cubby. Remove the cubby and you can easily access it. Its out of the tire spray zone there (as evidenced by the lack of mud I had up there :) )
  16. Aug 19, 2018 at 12:48 PM
    #56
    Joisey
    Joisey Well-Known Member
    Male pipe thread hose barb:
    Pipe union:
  17. Aug 25, 2018 at 8:46 PM
    #57
    D.W.B
    D.W.B Well-Known Member
    Dennis
    Mar Vista, CA
    TRD OFF-ROAD
    How come something so simple can turn into a nightmare?
    I ordered the parts mentioned by Tommyvue on page one and today I decided to start the mod.
    I removed the left rear light, routed the hose and removed the factory breather, it came off fairly easy. When I tried installing the new one it wouldn't go in no matter whatn not even even one tread. I tried at least ten times and my neck start hurting so I decided call it the day and install the old back. It went in really easy just screwing with my fingers a few turns, used a wrench to snug tie and the union would just turn and turn and turn and never get tight. Tried to revove again and would just turn and turn and it wouldn't come out.
    How much of a problem do I have now?
  18. Mar 18, 2019 at 3:09 PM
    #58
    Minimag95
    Minimag95 Well-Known Member
    Niles
    Annapolis, MD
    2009 Pyrite Mica V6 SR5 4x4
    OME's w/ 887 Coils, SPC UCA's, 285 ST Maxx. Mobtown sliders & skid
    Sorry to revive this thread, but I've done a lot of reading and there seems to still be conflicting info on part numbers for this mod. I've made a list of the part numbers that I've read about people using:
    90404-51026
    90404-51319
    90404-51052
    90930-03097
    90930-03136
    Which two do I need? So many people are doing this mod with different part numbers it's gotten pretty confusing
  19. Mar 18, 2019 at 3:40 PM
    #59
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Breather - 90930-03136
    Union - 90404-51319
    Not speculating. I did it not long ago and looked up my orders for ya.
  20. Mar 18, 2019 at 3:48 PM
    #60
    Minimag95
    Niles
    Annapolis, MD
    MountainManGuy likes this.
