Rear Diff Breather Relocate Opinions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WestCoastBestCoast, Feb 2, 2020.
Which spot did you use for the diff relocation?
  1. Behind Tail Light
    19 vote(s)
    67.9%
  2. Bed Pocket
    9 vote(s)
    32.1%
  1. Feb 2, 2020 at 6:36 PM
    WestCoastBestCoast
    WestCoastBestCoast [OP] Well-Known Member
    Wyn
    Portland, OR
    2005 SWB TRD 6MT 4x4
    Gonna do the rear diff relocate mod. Looking for opinions on where to put it.
    Looks like most popular are either in one of the bed pockets or behind the tail light.
    Opinions on either place? Any pros or cons of each location?
  2. Feb 2, 2020 at 6:39 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    Tail light. Pretty easy to route and higher up than the bed cubby. Just unbolt the tail and you’ve got full access.
    JVL1985, gabbo2112, Sna and 2 others like this.
  3. Feb 2, 2020 at 6:40 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
  4. Feb 2, 2020 at 7:05 PM
    WestCoastBestCoast
    Wyn
    Portland, OR
    Im leaning towards behind the tail light. Primarily cause no drilling. But just wanted input I guess.
    hdn4space, Sna and DG92071 like this.
  5. Feb 2, 2020 at 8:45 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Taillight. Higher up. No need to drill unnecessary holes.
    Sna and Muddinfun like this.
  6. Feb 2, 2020 at 8:46 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I put it inside the fuel door. My logic was simple, "If water gets up high enough it's in the fuel door I'll have other issues..."
  7. Feb 2, 2020 at 8:50 PM
    Slum Lord
    Slum Lord Well-Known Member
    Not sure why you need anything more then the vent hose to be zip tied to the filler neck in the bedside.
    If you are up to water past the kick panels your truck is destroyed. Your diff oil is the least of your problems at that point.
    Plus if your axle ever decides to puke it will either be over your gas cap or tail light.
  8. Feb 2, 2020 at 8:54 PM
    Bejabbers
    Bejabbers Well-Known Member
    Shane
    2001 Tacoma TRD DoubleCab 4x4
    3"SL 1.5"BL,2.5" exhaust,custom bumpers,Warn 8274,235-85R16's,Flex-a-lite Electric fans, AFE CAI, 18" Magnaflow, High flow Converter, 1.5" BL, Fabtech coilovers, AllPro Expedition leaf packs, Daystar 1.25" extended rear shackles, Billstein 5165 remote res rear shocks, Custom ARB style plate bumper, Singer 275Amp high output alternator, URD MAF sensor calibrator, Innovate MTX-L Wideband O2 sensor, ScanGaugeII, Tundra front brake upgrade, 3" extended braided stainless brake hoses, Cooper Discoverer ATW on Mickey Thompson Classic Baja Lock wheels
    I vented mine to where the gas filler is
  9. Feb 5, 2020 at 3:57 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    I used the cubby. I went so far as to put a loop in the hose to act as a trap. The end of the hose extends above the cubby.
