Rear Diff Breather (Relocation) Problems?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by roguegs, May 9, 2018.
  1. May 10, 2018 at 7:16 PM
    #41
    roguegs
    roguegs [OP] Well-Known Member
    Angelo
    V8 T4R
    Went from 3rd Gen Taco to 3GT4R to 2nd Gen Taco and finally a V8 4GT4R.
    Yeah I replaced the crappy one that came from the factory and used the same breather that all the other threads are referring to (still from Toyota). It’s the same breather that’s used for the front diff which, from what I understand, is also a two way.
  2. May 10, 2018 at 7:19 PM
    #42
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Ok I know what you’re saying.
    A lot of members have even made their own and put an aquarium filter on the end and put it up higher in the bed or engine bay and it’s open both ways.
  3. May 10, 2018 at 8:24 PM
    #43
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I like the way that ARB union looks. Sexy little piece. Is that hard plastic line or is it more flexible?
  4. May 10, 2018 at 8:28 PM
    #44
    Grossomotto
    2017 4WDV6LB6MT
    They’re hard plastic of some sort, but it’ll last just as long as anything else unless it gets pinched.
    The great thing about the ARB is you can run up to 4 lines into it. I’m going to do the front diffs, Tcase and manual trans even though they are extended. Just want to change out the one way OEM breathers which I’m not a fan of. I think the little mother fuckers have caused millions of dollars of damage for Toyota owners and the company.
  5. Jul 17, 2018 at 5:19 AM
    #45
    seedy_tea
    seedy_tea Well-Known Member
    chris
    Cape Cod
    2009 TRD-OR DC
    did you notice any side effects when this occurred? growl, vibration, etc?
  6. Jul 17, 2018 at 5:39 AM
    #46
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    2nd gen at 180k miles and been chasing the seep by retorquing the diff bolts too............I like how they receipt says removed diff and replaced gasket all easy peasy but doesn't removing diff still require removing brakes and pulling axles to free up diff? Not seeing how it wouldn't. That makes the DIY job much more involved. I won't replace that gasket unless putting in new axle seals, new brake shoes (and drums if needed) and would be concerned about pinion seal as well.........at my mileage. Definitely not blaming the rr diff breather mod tho.
  7. Jul 17, 2018 at 5:48 AM
    #47
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    I had the same issue on my 2016 7k miles and no leak. When I removed the factory breather the diff was under vacuum which I believe they are 1 way valves or it was broken. Well after installing the new valve 2 way it start leaking just like your pic. torqued each bolt a 1-2 lbft more and leaks been gone 35k later.
  8. Jul 17, 2018 at 7:31 AM
    #48
    Grossomotto
    2017 4WDV6LB6MT
    Well I did the ARB breather change and relocation at about 3000 miles on the odometer, so I don't think there was time for any side effects to happen. The diff was highly pressurized I know that and the stock breather was basically stuck shut after I took it off.
    seedy_tea[QUOTED] likes this.
  9. Jul 17, 2018 at 7:33 AM
    #49
    roguegs
    Angelo
    V8 T4R
    Diff breather relo has been on for about 6-8K miles now after the TSB work. Several wheeling trips, highway driving, and a couple water crossings and there’s no seepage/weeping any longer. I’ve been keeping my eye on it almost every week and don’t see anything
    tcjacado likes this.
  10. Aug 8, 2018 at 8:08 PM
    #50
    roguegs
    Angelo
    V8 T4R
    Update - there is slight weeping again but it is no longer on in random locations on the diff it is more focused on the drivers side half of it.
    Taking it to toyota tomorrow.
  11. Aug 8, 2018 at 8:35 PM
    #51
    Grossomotto
    2017 4WDV6LB6MT
    Awesome did you actually change out the breather as well like an ARB or two way or keep the stock breather and put up higher?
    Ok looks like it’s at it again, keep updating I’m interested what Toyota says
  12. Aug 8, 2018 at 8:45 PM
    #52
    roguegs
    Angelo
    V8 T4R
    I changed out the breather to the one that is linked at the bottom of the page. I might end up purchasing the ARB kit just because. Granted, the weeping isn't as bad as before but I might have just caught it at the right time.
    I will see what the dealer says tomorrow.
  13. Aug 8, 2018 at 8:56 PM
    #53
    Worrom1
    Worrom1 Well-Known Member
    16 taco 4 door lwb
    3inch pro comp with all 265/75/16 BFG AT
    I read somewhere here the new torque spec is 28 # old spec was 18# I put mine at 25# and montering they were pretty loose
  14. Aug 8, 2018 at 8:57 PM
    #54
    roguegs
    Angelo
    V8 T4R
    I would have hoped they torqued to the new spec from a couple months ago. I could torque them myself but I would rather have toyota deal with it since they should honor their workmanship
  15. Aug 8, 2018 at 9:00 PM
    #55
    Worrom1
    16 taco 4 door lwb
    If you have the time to deal with the dealer I would agree
  16. Aug 8, 2018 at 9:01 PM
    #56
    roguegs
    Angelo
    V8 T4R
    Thanfully it's only a 10 minute drive from me but I also wanted to get that TSB done for the funky acceleration.
  17. Aug 8, 2018 at 9:03 PM
    #57
    Worrom1
    16 taco 4 door lwb
    Good luck to you I need to get my 016 in for the update as well
    roguegs[OP] likes this.
  18. Aug 9, 2018 at 2:24 PM
    #58
    roguegs
    Angelo
    V8 T4R
    Dealer called and did not notice any weeping. To be frank, it didn't look like anything to me either but I wanted to be sure. No diff oil were on my bolts and it wasn't wet to the touch like last time. So maybe it was just some mud sticking onto it from my previous wheeling trip.
  19. Aug 9, 2018 at 6:09 PM
    #59
    Harvo
    Harvo Hanging On !!!
    17' TRD Offroad DCSB
    SpiderTrax, RCI Sliders, Warn bumper, Smittybuilt winch, Ridge Grapplers...
    I used a small gas filter for my breather mod end. So it breathes... both ways.
  20. Aug 9, 2018 at 6:31 PM
    #60
    sd1uh8as
    sd1uh8as Well-Known Member
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    Did they just install the TSB for you or they tested it first and go from there?
    My dealer here said they need to test first. Im thinking how are you going to check at 7am appointment the start of rush hour traffic..
    roguegs[QUOTED][OP] likes this.
