Rear Diff Breather
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mark_R, May 9, 2016.
  1. Jun 17, 2020 at 6:53 AM
    #41
    Pilsner
    Pilsner Well-Known Member
    18 TRDOR
    255/85r16 ST Maxx 6112/5160 w/ Dakar RCI armor, sliders, and rear bumper CBI hidden winch mount w/ Smity 20k
    I think the front already has an extended breather.
  2. Jun 17, 2020 at 6:56 AM
    #42
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    If it pukes fluid all the way through the tube, you have bigger problems -- like your truck is flipped over. I used the tail light location and just used a small crank case breather.
  3. Jun 17, 2020 at 7:19 AM
    #43
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    This ^^
    12020rixtactoy likes this.
  4. Jun 17, 2020 at 8:45 AM
    #44
    JVL1985
    JVL1985 Well-Known Member
    2019 Tacoma Double Cab, short bed,4x4, v6, TRD Off-road
    I come from the jeep world and in one of my old grand cherokees the diff would occasionally squirt out some fluid even though the breather line was way up high. I had it routed near the tail light also and the fluid would would get all over the back of the taillight and drip down to my bumper. I never took the time to remove the taillight and check it. I figured that as long as it wasn't clogged it was all good. Granted that jeep was a rock crawler and would see extreme angles and stress on that rear diff when it was locked. Nothing was wrong with the diff either. I did the maintenance regularly and everything was always good. I plan on babying this Toyota. It's too expensive to crawl it. So you are probably right. But I still rather put the breather someplace else, so it's ready for me to actually crawl it when it hits 200k miles.
  5. Jun 17, 2020 at 8:50 AM
    #45
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    It does, the kit comes with 2 higher quality 2-way valves for the front.
  6. Jun 17, 2020 at 9:22 AM
    #46
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I think I’d rather have it drip down behind the tail light than in the fuel neck / down the side of the truck. Also, I think there’s a vent there that goes to the evap.
  7. Jun 17, 2020 at 9:38 AM
    #47
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    LoL! Don't do this:
    Attached to the tail of one of the accessory rail fasteners with safety wire and a jam nut.
    I was heading out for some wheeling the next day and expecting some deep water. I wished that I had a stick-on zip tie anchor or knew about the tail light location idea.
    The schmoo has not been released in the past couple years. No extreme angles though.
    JVL1985[QUOTED] likes this.
  8. Jun 17, 2020 at 9:57 AM
    #48
    JVL1985
    good point. I just thought it would be easier to notice and wipe down. But if there is an evap vent in that location I wouldn't want to get that clogged up either.
  9. Jun 17, 2020 at 10:24 AM
    #49
    CPS-65
    CPS-65 I’m good for some, but I’m not for everyone.
    Alta Loma, CA
    2019 Quicksand TRD Off Road 4X4
    Mostly old man mods
    I've used axle breathers with remote outlets before. I generally think they are a good idea because moisture and contaminates in the lubricants will damage the gears, bearings, and differential components over time. Rust can be an issue, but secondary to the damage caused by decreased lubrication properties and increased abrasion from introduced grit. If you drop your lubricant and get a milkshake, the damage has already been done.
    Many axles come with a pressure operated burp valve on top which are generally fine, however, if you find your axle getting submerged more than a dunk; e.g. sitting submerged on a boat ramp for an extended period, a long deep water crossing, or stuck in a submerged situation. Some water is going to get in. That water will have suspended contaminates in it, and while it may not cause a failure on the drive home it will do damage over time. How much do you think it would cost to change out the gear set, bearings and locking diff in one of our trucks? The mind wobbles.
    I looked at the thread on putting one of these together. It seems okay, but I am not a fan of nippled fittings, rubber hose, and worm screw clamps. I've used AN fittings and PTFE or silicone hose in the past and they have worked well. Rubber hose cracks over time and will require watching. worm screw clamps loosen and require attention. a loose hose here is far more a concern than how well the factory setup keeps water out.
    tonered likes this.
  10. Jun 17, 2020 at 10:27 AM
    #50
    JVL1985
    what do you have on your truck now?
  11. Jun 17, 2020 at 10:29 AM
    #51
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Looks like it
  12. Jun 17, 2020 at 10:50 AM
    #52
    JVL1985
    I just checked that location. It appears the small hole at the bottom does not directly connect to that evap vent. I can see right through to the other side, so I assume it's their for water/ fuel spill drainage. I wonder if clogging that evap vent is possible doing something like the second picture below.
  13. Jun 17, 2020 at 11:24 AM
    #53
    Skydvrr
    Nick
    YMH
    Black '17 OR
  14. Jun 17, 2020 at 12:19 PM
    #54
    JVL1985
    I have time today so I just crawled under to see if I can find that hole from the back. I could see it and managed to take a decent picture. I confirmed it's the same hole by closing the fuel door and I could no longer see it from the back. I think the image you posted is a diagrammatic representation of the system (which I can see those evap hoses in my picture). But it is not accurate in that the hole below the fuel cap doesn't directly connect to the vent hoses. The diagram must be leaving out the weep hole in the plastic compartment since in the context of the evap system the weep hole doesn't seem to be relevant. Thanks for going down this rabbit hole with me.
  15. Jun 17, 2020 at 12:23 PM
    #55
    OregontoBajaCA
    OregontoBajaCA 2025 DC OR High Bread
    2025 OR DC iF Max
    With a canopy on the bed and slot covers for the storage box this location now stays clean and dry.
    DB59DDE6-C02A-46E6-BBB8-C03B8D78DAC4.jpg 30B19E0A-6DEE-469E-B0B1-E2185EE69587.jpg
  16. Jun 17, 2020 at 12:25 PM
    #56
    JVL1985
    My 2019 doesn't have the cubby on the driver side so I might do this with the cubby on the passenger side.
  17. Jun 17, 2020 at 12:29 PM
    #57
    OregontoBajaCA
    2025 OR DC iF Max
    That should also work well.
  18. Jun 17, 2020 at 12:34 PM
    #58
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Driver's side cubby seemed like an easy location to me.
  19. Jun 17, 2020 at 1:08 PM
    #59
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Interesting. So that’s the fuel spillage hole and the one to the left must be vent eh?
    eta: looks like it’s behind that bezel. That’s good to know
  20. Jun 17, 2020 at 1:11 PM
    #60
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I believe that smaller hose and attached piece is the vent and valve.
