Rear Diff Fill Plug - Welded on?!? Help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by YYC, Aug 26, 2013.
  1. Aug 27, 2013 at 5:14 AM
    #41
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    He's not saying use a manual impact driver, but rather literally hit the head of the bolt with a hammer.
    I've done it on some stubborn head bolts, helps loosen them up, works wonders.
  2. Aug 27, 2013 at 5:19 AM
    #42
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Just pull an axle and tilt it sideways
  3. Aug 27, 2013 at 6:42 AM
    #43
    obscurotron
    obscurotron Well-Known Member
    N. Nevada
    '14 DCSB 4x4
    Too many to list, and I've probably forgotten a bunch.
    Fill plug is hollow on these. Since we're talking about the rear diff and not something more sensitive, I'd get a good 3/8" HSS bit, and drill out the center of the plug. Then I'd toss in a good 3/8" nipple extractor, grab it with a 24" pipe wrench (for extra leverage, you may want to try an offset pipe wrench) and break the sucker loose.
    Added benefit is that if that method fails, you've hollowed out the plug along it's full depth. Put a chisel perpendicular to the new hole, and beat on it with a hammer. The idea is to collapse the plug. If you do it right, it won't hurt the threads in the diff. housing. If the walls are still too thick to collapse, re-drill with a 1/2" bit and try again.
    It'll come out. If 1/2" won't do it, go to 5/8". I wouldn't go bigger than 5/8".
    I don't know if the threads in the housing are IPT or not. If they are, and if you can find one (goddamn metric system!), I'd replace that fill plug with a brass plug. You can get them in square drive (internal) like the front diff plug, but square instead of hex. Brass is easier to de-mangle next time around, and it won't rust *to* the steel (it will corrode, of course).
  4. Aug 27, 2013 at 6:48 AM
    #44
    Round II
    Round II Member #12005
    :eek:
    This^ Also most of the time if you apply a lil heat it will make it easier for removal, though I'm sure you're past that point now.
  5. Aug 27, 2013 at 6:54 AM
    #45
    kai38`
    kai38` Well-Known Member
    Before removing it get a new one to replace it and have on hand.
    I had a similar problem took it to a shop and the put an impact wrench on it to get it off.
  6. Aug 27, 2013 at 3:26 PM
    #46
    malbanese
    malbanese Active Member
    Houston Tx
    2013 Tacoma dclb spruce
    Hood struts, weathertech 5100's all around allpro skid dif vent mod undercover
    I've removed many a stubborn bolt with a little heat. In fact everyone I could not get out with other means finally yielded when the torch was applied. Welding on a nut is another good idea if you can't get hold of it.
    On a side note ,when get to replacing the plug, use pipe dope on the threads and you'll never have this problem again.
  7. Aug 27, 2013 at 3:30 PM
    #47
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    This....heat may be the key. Also, as last ditch effort vise grips and heat it a bit with a torch.
  8. Aug 30, 2013 at 6:39 AM
    #48
    YYC
    YYC [OP] Member
    Calgary, AB
    DCLB TRD Sport
    slowly happening!
    So I went to see a welder and he welded a bolt on to try it, sheared the head clean off. Then he welded a nut to the remaining bolt threads, same result!!
    He gave up and didn't even charge me for the work.
    Looks like my only two options left are to drill it out or fill through the breather.
    Thanks everyone for the suggestions, very much appreciated!
    Al
  9. Aug 30, 2013 at 8:52 AM
    #49
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Take it to a good mechanic.
  10. Aug 30, 2013 at 9:10 AM
    #50
    vtrguy
    vtrguy Well-Known Member
    Jarrod
    Chico
    '01 Taco TRD xCab SR5
    Deckplate, Full OME kit, Snugtop Camper, Camry ignition ring, TRD Catback
    eff it.
    Drill the whole thing out and re-tap for a larger bolt.
  11. Aug 30, 2013 at 10:49 AM
    #51
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    If it were mine I would weld another bolt on it, then let it cool completely and use a torch to heat only the TC. Try to heat the case around the bolt and it should expand slightly. Then it should come off easy.
    Drilling it might be a hassle, you'll have to flush it really, really well after to make sure there is no metal in your gears.
  12. Aug 30, 2013 at 10:59 AM
    #52
    rhavin42
    rhavin42 Well-Known Member
    Vladimir
    Phoenix, AZ
    09 DC LB SPORT 4x4
    subbed to see where this ends up :popcorn:
  13. Aug 30, 2013 at 11:09 AM
    #53
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    Wow, I though mine was bad. Sub'd for outcome, make sure you anti-seize the new bolt if you ever get the old one out.
  14. Aug 30, 2013 at 12:45 PM
    #54
    mr2mki
    mr2mki Well-Known Member
    If you're good with a drill, you might be able to coax the bolt into collapsing before you actually drill the threads out, and then you could just scrape the pieces out of the threads, clean up the threads and use a factory bolt.
  15. Aug 30, 2013 at 2:18 PM
    #55
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    this is ugly!!
    did you allow everything to cool before you yanked on it with a wrench..after welding?
    i wonder if the plug expanded and got tighter from the heat.
    too late, but i would have banked on a big bolt out. they make lug nut sized ones now.
  16. Sep 2, 2013 at 9:10 AM
    #56
    YYC
    YYC [OP] Member
    Calgary, AB
    DCLB TRD Sport
    slowly happening!
    In fairness I don't think it was fully cooled before he tried the wrench on it. Poured a bit of cold water over it until it was cool to the touch.
    Up close its hard to tell where the bolt head ends and the diff begins.
    Not many people seem keen on filling through the breather, but I honestly don't think this bolt is going to give and drilling it may put too many shavings in the housing. This is beyond frustrating!!
  17. Sep 2, 2013 at 9:12 AM
    #57
    YYC
    YYC [OP] Member
    Calgary, AB
    DCLB TRD Sport
    slowly happening!
    Sounds straight forward but could you please elaborate on the process?
  18. Sep 2, 2013 at 9:30 AM
    #58
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    You pull the 3rd, write up in stickies on top of this forum, then you could either drill it out or seal it up and then drill a new hole above and weld in a bung for an oversized fill/inspection port. Like ruff stuff does with their housings. Then you can clean all the crap out of the housing. Its not too bad...
    Either way you should probably pull the 3rd at this point.
  19. Sep 2, 2013 at 9:31 AM
    #59
    92LandCruiser
    Nevada
    Cummins, tons, 40s
  20. Jun 28, 2014 at 3:34 PM
    #60
    YYC
    YYC [OP] Member
    Calgary, AB
    DCLB TRD Sport
    slowly happening!
    Reviving an old thread but some were interested in the outcome.
    Cost me 30mins of Toyota Dealer labour. Worked out to $40 and in the end I just had them drain and fill the diff, but at least I'll be able to do it myself the next time.
    Thanks again to all who posted their suggestions. No thanks to person who did the last fluid change!
    Cheers,
    Al
