Getting the rear diff fill plug off?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Zaothusia, Jun 9, 2018.
  1. Jun 9, 2018 at 5:56 PM
    Zaothusia
    Zaothusia [OP] Crawl Dad
    Justin
    southwest florida
    06 royal blue Tacoma sr5 TRD Sport
    trail rack, yellow fogs, saving for a new suspension
    Is there anyone in the central Pennsylvania/South York location that can help me get the rear diff fill plug off and put a new one on? I'm trying to save a $400 dollar trip to the stealership! For routine oil change and preventitive maintenance. I've already been told Advanced Auto Parts doesn't have a fill plug in there entire inventory.:thumbsup: Way to go guys you can't carry a $4 Flipping fill plug. they have the drain plug. But not the fill plug.:mad: this darn thing is so seized up its like they welded the entire plug to the cover :frusty:
  2. Jun 9, 2018 at 6:33 PM
    Dennisi01
    Dennisi01 Well-Known Member
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    Have you tried spraying a penetrating oil a few times daily for a few days? I did that and used a piece of pipe as a cheater on my ratchet and it came off without a problem. Fwiw my bolt wasnt touched in 8 years prior..
    Zaothusia[QUOTED][OP] likes this.
  3. Jun 9, 2018 at 6:47 PM
    Zaothusia
    Justin
    southwest florida
    I used some pb blaster and then got impatient I ended up drilling a hole in it and I'm getting an extracter kit tomorrow
  4. Jun 9, 2018 at 6:56 PM
    Zaothusia
    Justin
    southwest florida
    I will be adding more pb blaster tomorrow also.
  5. Jun 9, 2018 at 7:24 PM
    1E7DCSB
    1E7DCSB Well-Known Member
    NH
    ZEP45, a socket, and tapping the end of a breaker bar handle got mine right off but I’d use heat if you can’t get it off
    jboudreaux1965 likes this.
  6. Jun 9, 2018 at 7:41 PM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    6 point sockets > 12 point sockets if you have them.
  7. Jun 10, 2018 at 4:32 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Try tightening it a bit more first. You just need it to move a tiny bit before loosening.
    You drilled a hole in the fill plug??? Your gonna need a huge extractor. Here's hoping it doesn't shatter...:fingerscrossed:
  8. Jun 10, 2018 at 4:37 AM
    JMC3800
    JMC3800 Well-Known Member
    Western MASS
    2021 Off Road DCab
    You can try a chisel and hammer tap it maybe get some movement.
    FirstTimeFirstGen and NM Lance like this.
  9. Jun 10, 2018 at 4:47 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Weld a large nut to it through the center of the nut and use an impact.
    BassAckwards likes this.
  10. Jun 10, 2018 at 4:52 AM
    Dennisi01
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    OP lives on the edge.. drilling the plug out without another on hand!
    Larzzzz[QUOTED] and Blockhead like this.
  11. Jun 10, 2018 at 4:59 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Was thinking the same thing.
  12. Jun 10, 2018 at 5:02 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    You just might be better off having someone that has the experience and tools do it.
  13. Jun 10, 2018 at 5:12 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I’d be concerned about getting the metal chips from the drilling, out of the dif.
  14. Jun 10, 2018 at 5:25 AM
    Dennisi01
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    Would it be best just to take the whole rear plate off and spray it out good with something?
  15. Jun 10, 2018 at 6:33 AM
    rnish
    Tacoma 2nd gen
    My pumpkin doesn’t have a rear access and assume all 2nd gens are the same. Would have to drop the drive shaft and get in from the front.
    FirstTimeFirstGen likes this.
  16. Jun 10, 2018 at 6:47 AM
    WoodsGhost
    WoodsGhost Well-Known Member
    PA
    2017 DCSB OR:2016 4Runner
    Along with penetrating oil, applying light taps with a hammer can sometimes cause the rust to break apart enough to break it free. Harmonics.
  17. Jun 10, 2018 at 6:48 AM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    There is no rear plate, that's the housing?
    Man, I though I had done some extreme stuff before, but this takes the cake, lol!
    Removing a drilled plug with no extractor (worse case) is eazy sqeeezy orange peezy. Drill it close to the threads, use a dental pick to clear the threads.
    There's no junk yards you can get one from around there?
    Or, if you only need to get to the dealership, a buddy with a Tacoma who can park his for the day pull his, cover the hole, and let you use his for a few hours????
  18. Jun 10, 2018 at 6:52 AM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    No matter what, guys chime in here, 3rd member has to come off to get metal shards out :(
    TacoMitch93 likes this.
  19. Jun 10, 2018 at 7:38 AM
    1E7DCSB
    NH
    I replaced the plugs and gaskets when I did my 4wd service. It’s Cheap enough
  20. Jun 10, 2018 at 8:03 AM
    NM Lance
    NM Lance Well-Known Member
    This worked on mine.
