Rear Diff Filler Hole is Stripped
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ilovetacos, Apr 11, 2011.
  1. Apr 11, 2011 at 8:56 PM
    ilovetacos
    ilovetacos [OP] Well-Known Member
    Gavin
    Sacramento/Woodland
    2006 TRD Sport 4x4 DC
    Sold!
    It all started about a month ago when I went to change the rear diff fluid...
    I went to remove the filler plug and it just spun. I didn't attempt to remove it because I wasn't sure if it was the plug or hole that was stripped. I assumed it was the plug because the hole is more durable. I went to my local dealer and was able to purchase a couple filler plugs. Went back home drained the oil and then tried to remove the filler plug. Well it didn't want to come out. It just spun both ways. I pulled out while loosening it and it wouldn't come out...
    Long story short I ended up drilling the plug out (probably not the best way but was in a bit of a hurry). Found that the plug and the holes were both stripped. Looking at the filler hole I thought I could tap it. Went down to Harbor Freight, bought a tap and die set and was actually able to re-tap the hole. When I put the new filler plug in I didn't use a torque wrench because I didn't want to tighten it too much and strip the new "more fragile" hole. I just hand tightened it snug.
    All was good until today when I noticed the filler plug leaking. Well I assumed the plug became loose because it wasn't properly torqued. So I went to re-tighten the plug just now using care not to strip it and again it is just spins. I didn't attempt to loosen it because I don't want to remove the plug and the be unable to put it back it. There isn't a lot of oil leaking but it definetely needs to be fixed.
    So what are my options now?
    Should I attempt to re-tap the hole?
    Should I take it to a professional?
    Should I run it off a cliff and start over?
    Should I weld the existing filler plug closed and tap a new hole???
  2. Apr 11, 2011 at 8:59 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    Push it over a cliff and start over :D
  3. Apr 11, 2011 at 8:59 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    helicoil maybe?
  4. Apr 11, 2011 at 9:01 PM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    i dont know if a helicoil will hold to high torque like that, ive only used them for small stuff
  5. Apr 11, 2011 at 9:03 PM
    ilovetacos
    Gavin
    Sacramento/Woodland
    Sold!
    It is paid off and I have full coverage insurance...Hmmm.
    I did a couple searches here and the heilcoil idea came up but it wasn't recommended because of what D Dan said.
  6. Apr 11, 2011 at 9:19 PM
    Yoytoda
    Roland
    completely stock
    i said maybe LOL
  7. Apr 11, 2011 at 9:22 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    helicoil would slip out. There is another thread on either here or TTORA that some guy was having the same problem. There is another product like the helicoil, but ment for through holes (like the fill hole and not a hole that ends like the helicoil is made for).
  8. Apr 11, 2011 at 9:25 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    The filler plug should be at 36 ft lbs.
  9. Apr 11, 2011 at 9:27 PM
    krans
    krans Well-Known Member
    Kenny
    Huntington beach/ West min duh
    09 Sport mall crawler
    Icon extended travel with resi front and rear,Camburg UCA, All pro standard leaf pack, Fogs anytime, General grabbers AT2,Custom stainless steel brake lines,bed box, Bestop soft top,50' light bar, amber rigid pods,CBI ditch mounts with LED pods,TRD intake,Anti dark hoodlights/rock light/LED whip,FX-R retros and Gibson catback..more mods to come
    Maybe an option would be re tapping the threads next size up along with a new filler bolt.
  10. Apr 11, 2011 at 9:33 PM
    Badwin45
    Badwin45 Well-Known Member
    OKC
    '10 DC 4x4 & '00 Pre-Runner
    Aries 4" Oval step tubes, Brute Force Fab rear bumper, Weathertech digifit floor liners.
    I believe that was a Keensert.
  11. Apr 11, 2011 at 9:33 PM
    S.B.
    Sean
    Sounds right. Thanks for clarifying.
  12. Apr 11, 2011 at 9:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Re tap the hole and install a larger plug. 10 mins, and done.
  13. Apr 11, 2011 at 9:40 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    Just a thought...would a large nut welded over the fill hole and a short bolt in place of the drain plug be an option?
  14. Apr 11, 2011 at 9:40 PM
    JohnnYp
    JohnnYp Member
    Arizona
    98 SR5
    throttle body spacer k&N cold air intake stage 2 clutch kit Gibson cat back exhaust kit bed liner and rocker panel lined
    ^^^ X2
    lil teflon tape wouldnt hurt to :wave:
  15. Apr 11, 2011 at 9:42 PM
    S.B.
    Sean
    Would work, but there are better options.
  16. Apr 11, 2011 at 9:46 PM
    doormanndan
    doormanndan Active Member
    Dan
    Inland Empire CA
    06 Taco pre runner
    Take the plug out again and clean it up as best as you can. Chase the threads with the tap again and re-clean. Use several layers of Teflon tape on the plug and try again. Also I think Loctite makes a thread sealer and perhaps another product that will fill voids. A second option would be to go to the next US NF bolt thread size and re-tap, use grease on the tap to help trap some of the shavings. As far as sealing a threaded hole that is not a tapered like a pipe fitting, you could use a o ring or a bronze washer and some silicone underneath the head of the bolt. Be sure to cut the bolt down to the correct length so it has no chance to interfere with the diff
    Good luck
    Dan L
  17. Apr 11, 2011 at 9:47 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    I would re-tap it too. The hardest for you will may be to find the tap... (as most hardware stores here only carry small sizes.)
  18. Apr 11, 2011 at 10:18 PM
    ilovetacos
    Gavin
    Sacramento/Woodland
    Sold!
    Thanks for the response guys!
    I'm going to use doormandan's 1st suggestion. If that doesn't work I'll re-tap to a larger size.
    You can get the tap and die set at Habor Freight. It worked well the first & only time I used it.
    http://www.harborfreight.com/45-pie...ide-coated-alloy-steel-tap-die-set-41452.html
  19. Apr 12, 2011 at 4:42 AM
    Brunes
    Brunes abides.
    Rotorhead
    You could also try a self tapping drain plug from a truck parts place. Just get a size large enuf to cut a little bit out of the hole that's there. I would think that if the plug has done the same thing twice you are out of metal to use at that size. Gotta go bigger.
  20. Apr 12, 2011 at 5:06 AM
    Tckwarrior
    Tckwarrior Well-Known Member
    Aaron
    Damascus OR
    08 RegCab Superwhite
    3 inch revtek lift,American Eagle 197 Black Wheels 17x9 Boltpattern 6x5.5 , 285/70/17's with BFG km2s U-haul class 3 tow hitch, Better built toolbox. Trail-gear 58 inch Rock-sliders
    Buyers beware
