Rear diff fluid change mishap?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xxaarraa, Dec 27, 2011.
  1. Dec 27, 2011 at 12:22 PM
    xxaarraa
    xxaarraa [OP] Well-Known Member
    Hey guys,
    I did my 30k service today and replaced all the diff fluids - rear, t-case and front. Everything went well and I replaced with Mobil 1 full synthetic fluid (75-90). But... after doing the rear, I went to empty the old fluid into the empty Mobil 1 containers and noticed one of them said 75-140 and two of them said 75-90.
    I totally didn't catch the difference in weight so my rear now has 2 quarts of 75-90 and one quart 75-140, though all of them are Mobil 1 full synthetic "LS" formula. Will this be a problem?
  2. Dec 27, 2011 at 12:24 PM
    Sunner
    Sunner Well-Known Member
    I would just redo it, subbed for input though.
  3. Dec 27, 2011 at 12:25 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Nope you 100% good, nothing to worry. I mix mines on other trucks no issue:thumbsup:.
  4. Dec 27, 2011 at 12:25 PM
    cc350
    cc350 Retired Member
    OK to go..
  5. Dec 27, 2011 at 12:27 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I'd empty it and put in the correct weight.
  6. Dec 27, 2011 at 12:39 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    my axle leaks so bad i just replace it whatever weight fluid i have haha
  7. Dec 27, 2011 at 12:50 PM
    ManMan
    ManMan Well-Known Member
    With that mix you're effectively running 75w107. Not a big deal, I'd just go with it. Last time I worked on an axle, everything in there was roller bearings which really don't care what lube they have. The only critical tolerances were gear lash and side to side preload ... neither of which are really going to be affected by the oil weight. It's not like there are journal bearings with critical tolerances
  8. Dec 27, 2011 at 12:51 PM
    jeremy_283
    jeremy_283 Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    I'd do it the right way, and always check bottle labels :D
  9. Dec 27, 2011 at 12:53 PM
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    It wont matter, your good to go
  10. Dec 27, 2011 at 12:56 PM
    xxaarraa
    Thank you folks! :)
  11. Dec 27, 2011 at 1:30 PM
    WV150
    WV150 Well-Known Member
    South Carolina
    Trifecta Tonneau Cover
    Change it.Not good to mix weights.
  12. Dec 27, 2011 at 1:32 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
  13. Dec 27, 2011 at 1:42 PM
    Sunner
    A couple mixed reviews, personally Ide change it out just to be on the safe side but doesnt seem needed given a few of the reasons provided above.
  14. Dec 27, 2011 at 2:10 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Run it like it is.
  15. Jan 1, 2012 at 3:09 PM
    johnny 5
    johnny 5 Well-Known Member
    wisconsin
    Black 07 TRD Off road 4x4
    7-6'' sno-way plow w/DP
    My drivline runs all Valvoline synthetic 75w90 front diff rear diff and transfer case over 100,000 no troubles yet. Piece of mind would be not to mix weights. I never mix lubricants but atleast you have the same brand
  16. Jan 1, 2012 at 3:21 PM
    BlueT
    NorthEast
    mixing weights is standard proc. for example 75-110 is odd number but there are some diffs calling for it You get that by mixing 75-90 with 75-140 at 1:1 ratio.
  17. Jan 1, 2012 at 4:30 PM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    your good to go
  18. Jan 1, 2012 at 4:39 PM
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    It'll be fine! Probably a performance upgrade.
  19. Jan 1, 2012 at 4:52 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
