Rear diff fluid change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MapleSyrupSmuggler, Mar 30, 2018.
  1. Apr 13, 2018 at 8:39 AM
    #61
    MapleSyrupSmuggler
    MapleSyrupSmuggler [OP] Member
    18 AC TuRD OR
    Guess I'll be picking up more valvoline today. I felt like I almost stripped the drain plug a few times so I might replace it with the internal 10mm hex plug next time.
  2. Apr 13, 2018 at 9:29 AM
    #62
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    On the rear diff? It was probably overtorqued from the factory. I'd stick with a 24mm bolt, esp going into steel. It can take more loosening torque than a 10mm internal.
    Using the torque given in the OP, everything is looking great and no leaks.
    I think you will be fine down the road.
  3. Aug 21, 2018 at 6:50 AM
    #63
    longspear
    longspear Well-Known Member
    Daniel
    2011 Tacoma Dbl Cab TRD Sport
    887 Full OME Dakars 4Runner Trail wheels 255/80/17
    Just to give you all some perspective. Dealership quoted me $150 EACH to service transfer case, front and rear diffs.......I think i'll be doing this myself.
  4. Aug 21, 2018 at 6:57 AM
    #64
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    You can do all 3 for about $60 total
    The Tcase is specific weight not 75W90
    shakerhood likes this.
  5. Aug 1, 2019 at 11:05 PM
    #65
    SnowB
    SnowB Well-Known Member
    Brad
    Detroit
    1996 Toyota 4Runner
    Suspension and intake and bigger tires
    Redline heavy shockproof in diffs, trans, and transfer case has worked great for me for 295k miles. I have changed the fluids five times. Third gen 4runner
  6. Aug 2, 2019 at 4:53 AM
    #66
    Rparker017
    Rparker017 Well-Known Member
    2018 Tacoma TRD Pro
    ShiftSense Pro
    I’m a believer in changing out gear oil after a short break in period. Changed out the rear differential in my 2018 around 2,000 and there was enough metal on the plug and in the oil to make it worth doing IMO. After the break in change, I use 50k - 60k intervals.
    Regarding the plug gaskets, I almost never change them unless the old one looks gnarly. I keep a set on hand just in case. Worst case you wind up with minor seepage and can swap it out on the next change.
